Canada Serving Canada.
Cleaning - what products/from where/how much?
Old Jun 7, 2004 | 06:29 PM
Reqless's Avatar
Tsup all,
new owner, new member...
I was wondering what you use to clean your G's...
I have a black one, only had it two days now...some things that need cleaning already:
- streaks on the windows
- dust on the car
- brake dust on the rims
What are the products you use? from where? and how much?
Thanks,
Req
Old Jun 8, 2004 | 10:19 AM
jandc's Avatar
Re: Cleaning - what products/from where/how much?
Welcome.
I have high maintenance black too. I use the Zaino system (Z5, Z2, Z6). Once you prep your car, then light cleaning is easy with Z6 (like a quick detailer).
I use Zaino Z6
- dust on the car
Again, Zaino Z6
dish soap and water, then you guessed it, Zaino Z6
I ordered mine from www.carpolish.ca
Old Jun 8, 2004 | 10:29 AM
fluffydot's Avatar
If you want to make it easier on yourself, WAX your rims also. they probably won't need the full zaino treatment, but some or any kind of wax will help with keeping breakdust off them.
I use Crystal Guard (synthetic polymer sealant) and it works well for my white coupe. I always put some on my rims as well. and it makes cleaning them MUCH easier. you will never get any build up.
Old Jun 9, 2004 | 05:28 PM
Reqless's Avatar
Thanks, will order em right away...
(on another note, i was reading the 'tips' from the website...pretty hard to get straight instructions from them, in between all the obviously-biased plugs)
"buy canadian and american towels...foreign countries include polyester in theirs, because obviously they dont have cars worth buffing up over there"
haha
Old Jun 10, 2004 | 10:58 PM
derek's Avatar
From: Metropolitan South Farmington, not too far from the supercity we all know as Wilmot, NS
www.zaino.ca
Ecstatic with every product they sell.
Cheers,
Derek
DB
Old Jun 11, 2004 | 11:00 AM
PimpCoupe's Avatar
you can get Zaino from The Barber Shop at Square One in Mississauga. And yes, it is a barber shop that sells car stuff. I don't get it either.
2003 CB Coupe 5AT
ATI Procharger
Stillen Cat Back Exhaust
Eibachs
Gord G Grounding Kit
Old Jun 12, 2004 | 01:03 AM
derek's Avatar
Good call PC. I've bought stuff at the barber shop too, as well as making the road trip to Guelph. Makes sense to me. Get a haircut...buy car care products...all under one roof...yep, I can see the connection (??? this is where a "confused smiley" would go if I had downloaded some emoticons)
Cheers,
Derek
DB
Old Jun 12, 2004 | 07:45 AM
Reqless's Avatar
I've seen these kind of stores...one stop shops...they'll give you a haircut, file your taxes, do you laundry, wax your car and give you a handjob on the way out...
(all usually done by the same GUY...haha)
[anyone recommend buying the whole 127$ Zaino KIT?]
Old Jun 12, 2004 | 10:47 PM
derek's Avatar
Kit is a good way to go- only thing you may not be compelled to use is Z5, for a brand new vehicle. Recommend buying it anyway- you can use it on other cars or on your G later. Best tip I've seen is using a plastic dental syringe to dispense the Zaino. I got mine free from the phamacist. Takes about an ounce for a coat.
DB
Old Jun 13, 2004 | 03:09 PM
multimut's Avatar
Tip: Apply Zaino Thinly
Derek, you can apply more thinly than one ounce per coat. As you know, multiple layers adds to shine and protection, but applying thickly just wastes product. You should easily be able to get 3 coats from one ounce. My record is six coats (three each on two cars) from one ounce.
I find a high quality foam applicator wastes less product than the standard Zaino applicator. Put on applicator, and dab it around the section you're working on. Keep applicator moist spray of Z6 and/or very light spray of water.
Old Jun 15, 2004 | 01:26 PM
derek's Avatar
Re: Tip: Apply Zaino Thinly
Good suggestion on the Z6 in the app- I've only used water- I'll try the Z6. Thanks.
Cheers,
D
DB
Old Jun 15, 2004 | 11:39 PM
Jatt_G35's Avatar
Would'nt putting wax on your rims just make the brake dust stick on the rims even more??
Old Jun 16, 2004 | 11:07 AM
jandc's Avatar
The Z6 is not a wax - more like a quick detailer. I haven't tried Z2 wax on the rims yet but I suspect the brake dust will be easier to wipe off, just like how dirt/dust is easier to wipe off when you have a layer of wax on the car.
I did slap on a lot of wax (Meguires) on my other car rims for the winter to protect it from salt/etc. especially the lip, but by spring time it was truly a pain to clean off. Its as if the wax was baked on or something...
Old Jun 28, 2004 | 11:41 PM
kamikazeiG35's Avatar
What about for the interior? My '04 G35Coupe has been scotchgarded. Should I be careful with what I clean the seats with? I don't want to end up removing whatever he paid to have put on.
Al
Old Jul 3, 2004 | 09:53 PM
jandc's Avatar
Is your interior leather? Cuz I never heard of spraying scotch guard on leather. I think cloth is only an option in US and in very rare circumstances.
