Canada Serving Canada.
Rotors may be warped
Old Jun 1, 2011 | 05:34 PM
  #31
4DGS's Avatar
I too love Guelph infiniti. Best dealership to deal with.
I don't mind greg vann nissan either.
Old Jun 1, 2011 | 06:12 PM
  #32
whatacar's Avatar
Originally Posted by rpm&my_G35
Those guys at Guelph are great to deal with. They also ordered new door weatherstripping and the adhesive to fix them under the TSB.
I suppose I helped my cause by including the TSB numbers in my email yesterday.
Oh...and I got my lifetime free oil change while I was there
Cheers!
Good to hear Paul. They keep the d in dealership.
When I dealt with them I found them stand up as well.
Old Jun 1, 2011 | 07:59 PM
  #33
RBull's Avatar
Rated M
That's great to hear Paul. I didn't have that experience with my '08 with only 15K on it.
Old Jun 1, 2011 | 08:11 PM
  #34
Swivel's Avatar
Moderator
Good to hear they're taking care of you, Paul, they should for all the times you've had to go in for this issue.
I have a bit of pulsing, too, and have been debating having the rotors turned versus just taking them off, mounting them up to my drill press, and spinning them while using some garnet paper to remove the cementite deposits that are the likely cause. I've had new Wagner pads sitting around for a year or two.
Old Jun 2, 2011 | 12:11 PM
  #35
BabyGirl's Avatar
Glad to hear all worked out and Ian awesome information!
Not too long ago I found out that my cross drilled rotors were warped so I decided to get rid of them and go back to normal ones. Just wasn't worth it especially the headaches it was causing me and me getting into lapping I wanted to make my brake system was good
Old Oct 20, 2011 | 01:32 PM
  #36
Travellin007's Avatar
Well, I took my car in today, apparently I need new brake pads and rotors.
At 65,000 km, I can understand the new pads.
But new rotors I have difficulty with.
Nissan Guelph says there were 'hot spots' on the rotors causing the rotors, and the TSB's you get on the internet are not official.
Does my mileage exclude any work being done under warranty? The service girl says it only applies to under 20,000 kilometres.
Old Oct 20, 2011 | 01:44 PM
  #37
rpm&my_G35's Avatar
The TSB online are official. I show them (usually Mike or Kathy) a printed copy of each TSB before we get very far into the 'what needs to be done' conversation. When they know, that I know, what I'm talking about things go very well.
You didn't tell us what is wrong with your brakes. If it's just worn out brakes then it's your expense.
If it's judder or squealing there are official TSB's for the problem(s). The judder TSB makes no mention of a limit to how many km may be on the existing brakes.
Old Oct 20, 2011 | 03:08 PM
  #38
The girl at the desk did let on she looked into pushing the rotors through warranty, but they are too worn. I think if the problem had come up a year or so earlier things would be different. Just not very impressed right now with having to replace rotors....time to start shopping around, the quote was $1,100 from the dealership, and I'm not so sure I want to put the same stuff back on. Anyone with suggestions in Guelph/KW area, I'm all ears.
Old Oct 20, 2011 | 08:59 PM
  #39
gtoor1990's Avatar
pm me if you need rotors and pads
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
