Canada Serving Canada.
Minor issues with G...feedback greatly appreciated
Old Jul 29, 2009 | 12:43 AM
ScreaminG's Avatar
Exclamation Minor issues with G...feedback greatly appreciated
Hi guys, I've been having two minor issues with my G and I'm not sure if parts need replacement or if they need to be adjusted somehow...any experience with these two issues would be great for me to get the ball moving.
1) My passenger side seat can move back with the side seat control but not forward. However, if the passenger door is open and I push the top of the seat down to allow for someone to sit in the rear, the seat moves forward normally (by itself)! Could it be that the switch is loose? If the motor is working when the door is open it should when it isn't...
2) Power lock does not affect the driver side door, have to key in to open and lock manually from the inside. Have any of you experienced this without having to change the door lock actuator? Possibly the part linking the lock to the motor (that long "wire" with a edge that sticks into thelock point) being loose?
Thanks in advance
Old Jul 29, 2009 | 04:15 PM
zeadlots's Avatar
1) Motor sounds fine since it still moves when the auto-forward is activated for someone to get into the back seat. Sounds like the switch to me.
2)You sound correct on this one as well. If you can I would pull the actuator and see if you can make it work yourself....(you may be able to do this in the door)using an equal power source to the factory wire. Then you can eliminate the wire as the culprit right there and know if you have to replace the actuator.
My 2 Pennies.
Old Jul 30, 2009 | 02:04 PM
ScreaminG's Avatar
Thanks for the feedback, I did a little bit of reading on the seat and it turns out that someone had the same issue. Turns out dried out sugar from a minor coffee spill was sticking the switch in one direction.
I will look into the lock this weekend.
Thanks
Old Jul 30, 2009 | 09:02 PM
RBull's Avatar
Rated M
Thanks
Good to hear on the one simple fix. G/L on the other one.
jsimonk
Dec 22, 2023 03:49 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
ClwMike
Jul 23, 2015 12:55 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
