Canada Serving Canada.
Can anyone reccomend a decent A/C place in the GTA?
Old Aug 3, 2009 | 10:18 PM
kamikazeiG35's Avatar
I've got a 2004 6MT coupe and I don't use my A/C at all really. The only time I notice it is when I'm travelling on a humid day (and it rains) then the inside of your car fogs up. I usually flip on my defog thru the top of the dash and it's much cooler.
Anyways, long story short, during that crazed downpour last weekend, my windows were fogging so I flipped it on, to NOTHING... if anything my windows got WORSE. I had NO cooling power at all. I find that very odd, since as I mentioned I don't really use my A/C at all.
Does anyone have ideas as to what might have happened? I mean, does the coolant leak out over time, whether it's used or not? Or is there a blockage of some sort? Or is it some wiring? Or a dead compressor?
I've been running the A/C whenver possible to see if I can 'jolt' it back into action, but I get a mildly (and I DO mean mildly) cooler breeze, than when it first starts, but only slightly so. I could open a window and it would be cooler than that easily.
I'm hoping this is as simple as a coolant recharge thing, but I'm fearful of getting a huge bill for something far worse.
Anybody got a decent place that specializes in just this, that is trustworthy and doesn't charge an arm and a leg by the hour?
Any advice or suggestions would be greatly appreciated,
Al
Old Aug 4, 2009 | 01:33 AM
netcbc's Avatar
I'd recommend APH, they're very fair, I've gone there to do performance stuff and maintenance things when the G gave me problems, compression rod, window motor, etc..
Old Aug 4, 2009 | 10:21 AM
TroysG's Avatar
most places can recharge your AC for <100 bucks. if they charge you more than that go to a local sex shop buy the biggest ***** you can find slap it across their face and kiss my *** I'm not paying that
Old Aug 4, 2009 | 03:28 PM
GeeRider's Avatar
^ L-O-L , sumwun took in abit to much kush
Old Aug 4, 2009 | 06:19 PM
knight_yyz's Avatar
what about thos DIY kits you can buy now?
Old Aug 5, 2009 | 10:04 AM
I guess I was looking to figure out if it was jsut a matter of a recharge or whether I had bigger issues instead...
^+1 I've been seeing those 'green' kits too, has anyone had any experience with that? Is it easy to do?
Old Aug 5, 2009 | 10:08 AM
What does APH stand for? And where is it located? I can't find anything under just 'APH'...
thanks,
Al
Old Aug 5, 2009 | 01:39 PM
Darqfallen's Avatar
The DIY kits are good if you just need some time and you have a leak but unless you are going to go full out and buy a leak detection kit and patch the hole yourself take it to a pro. Also if it is a compressor you going to have to et the whole system refilled anyways not just the little that the DIY kits do.
Old Aug 6, 2009 | 04:27 PM
Good to know - to a pro then I go! Thx all for the advice!
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
mattdg35
Sep 14, 2015 11:28 AM
jbmw002
Sep 3, 2015 08:42 PM
