Canada Serving Canada.
2004 Sedan Driver Seat Right Track Locked Up
Old Sep 13, 2009 | 06:46 PM
frostryder's Avatar
Unhappy 2004 Sedan Driver Seat Right Track Locked Up
Hi,
I've search the forum and I wanted to know if there are any GTA drivers that have experienced the same problem:
https://g35driver.com/forums/g35-sed...lp-please.html
https://g35driver.com/forums/g35-sed...rack-help.html
how much it would cost to fix this and does anyone recommend a place?
thanks
Old Sep 15, 2009 | 07:00 PM
Hossmaxima's Avatar
I am experiencing the same problem. If you play around with it, it will eventually kick in. You would have to find the motor separately because Infiniti sells the whole seat bottom as a whole, you can't buy just the motor.
Old Sep 15, 2009 | 10:00 PM
frostryder's Avatar
thanks, I will keep messing around with it. I called couple dealerships the seat bottom will run approx $1,014 plus 3 hours of labour.
Old Sep 17, 2009 | 03:39 AM
SKperformance's Avatar
Or buy some used seats
Old Sep 19, 2009 | 05:20 PM
G-MAN (CANADA)'s Avatar
+1 thats what i would do. My driver seat kinda feels like I'm starting to get some play at certain times, I hpoe its not that.
Old Sep 22, 2009 | 03:33 AM
i mentioned that because i have a set for sale . LOL
Old Sep 22, 2009 | 08:42 AM
sdnpaul5at's Avatar
I had the same problem, cost me $0 to fix, the motor is most likely fine, atleast mine was, I was able to hear the motor but the right track was stuck. I took the seat apart to access the motor & what I found was the actual gear which is a round plastic piece the size of a dime was totally warn out, the teeth were gone, so I took the piece with me to a wreckers, found an INFINITI with power seats & matched the piece. I installed the new gear & it worked like a charm.
Old Sep 23, 2009 | 02:26 PM
frostryder's Avatar
thanks, I had a friend look at it, one of the motors is gone and I called around and couldnt find an used seats so I'm going to wait on fixing this.
Old Oct 7, 2009 | 05:16 PM
bruther's Avatar
I recently bought a seat track for the gear. I have an extra gear and motor if you would like to purchase.
PM if interested.
Brian
Old Nov 21, 2009 | 03:34 PM
evenwe's Avatar
seat track motor
I am interested in gear for seat track motor on 2005 infiniti g35. can you assist?
Old Nov 22, 2009 | 05:18 PM
evenwe's Avatar
I found a place that says it makes the gear for the g35 seat track. It's at http://www.odometergears.com/infiniti.html
does anyone know how to remove the original gear? seems there's a nut in front of it that needs to be removed, but I can't figure out how to stop the shaft from spinning when I try to remove nut.
slider_ua
Jul 29, 2015 04:17 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
brian_z
Jul 20, 2015 01:30 AM
mushu
Jul 15, 2015 03:55 PM
