Canada Serving Canada.
about lowering sedan
Old Oct 4, 2009 | 04:31 PM
swk401240's Avatar
hi ppl i have a question of lowering
do i just need springs to lower my sedan? or are there more stuff to buy?
im thinking of getting bit cheap spring around 100 ~ 200
plz help anyone have a good knowledge as i am not good internet user to find out resources
thx
Old Oct 5, 2009 | 09:28 AM
Mmagic76's Avatar
They recommend having Sport Shocks (red tubes) for anything up to 1" drop. Anything greater than that, you should look at getting new shocks with the springs. As well, you would need a 4wheel alignment. If you do more than a 1" drop, you'll probably want to get camber kits to save your tires as well.
Old Oct 5, 2009 | 11:48 PM
canucklehead's Avatar
^ +1. get the shocks if you can, otherwise just the springs won't kill you. you must get an alignment, but wait a week or so in order for everything to settle.
when i did my drop i bought the non-reusable nuts & hardware from a nissan dealer, i think this was about $12.
plan on about 4 hrs for a complete swap, but i suggest a spring compressor for the job.
Old Oct 6, 2009 | 01:11 AM
swk401240's Avatar
im thinking of getting H&R sports spring..sport shocks maybe if its not expensive but
for alignment if i take to the shop would they have it? or do i have to buy? srry im still very newbie in the mechanical world
Old Oct 6, 2009 | 08:36 AM
Mmagic76's Avatar
I'd recommend shocks, might as well replace them now than spend 2x the amount of time when your shocks are blown within the year (could be sooner or later).
Alignment is done at a shop. It's a service job not a part.
Old Oct 6, 2009 | 11:07 AM
??? what do you mean?
an alignment is a process that basically resets your suspension setup to within acceptable tolerances to prevent excessive tire wear or unsafe handling dynamics.
you need to take it to a shop that does suspension work. plan on ~$100 for labour.
google it to learn more.
Old Oct 7, 2009 | 06:31 AM
4DGS's Avatar
Assuming you're going to need a shop to install the springs as well. You're looking at probably $250 labour on the install.
Old Oct 7, 2009 | 07:24 AM
35bills's Avatar
Welcome to the world of modding...its only money afterall..
You start with one idea and then you find out that you have to have other things done also.
Springs...get used
You will most likely need a camber kit for the rear..you will see after the alignment is done...
Shocks...be prepared to change them out. I had the red ones but changed them this year( after 5 years of being lowered...car is 7 years old now)
End links...they wear out too
Upper shock mounts...possibility of them being seized...common with the G
Good luck...
Old Oct 7, 2009 | 11:19 PM
Swivel's Avatar
Moderator
Find someone with basic mechanical skills to help you with the install and save enough $$ to pay for an alignment at a shop.
Old Oct 8, 2009 | 08:33 AM
swk401240's Avatar
dam this is more than what i can bargain for ... lol well i guess start save up now since winter is coming and prepare next year
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
mann1961
Aug 9, 2015 08:44 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Kal Hamm
Jul 24, 2015 08:55 AM
