Canada Serving Canada.
Why an SES light when running Test Pipes???
Old Jan 4, 2010 | 07:29 PM
G-MAN (CANADA)'s Avatar
I have a chance to pick up a set of Res. test pipes on Fri, the price is good but it kinda bothers me that I'll have my "Service Engine Soon" light on. Is there any way I can get the light off by tricking the ECU? I have a code reader but if I reset it will just come back in a day.
Old Jan 4, 2010 | 07:39 PM
red35's Avatar
Try getting some Anti-foulers. You thread these into where the sensors go then thread the sensors into the anit-foulers. This should clear the problem of the SEL light. Its the most common fix.
https://g35driver.com/forums/v36-diy...t-hfc-fix.html
Old Jan 4, 2010 | 08:30 PM
knight_yyz's Avatar
will a dual output o2 sim work? The secondaries monitor the catalysts to see if they are working, since they are not there (precats), they are not working. so you get an SES.
Old Jan 4, 2010 | 09:58 PM
pinkii's Avatar
if not you will have to reset it every few hundred miles or when it gets really cold. I have to do that and I dont even have test pipes... damn HFCs. lol
Old Jan 6, 2010 | 07:04 PM
Hmm never heard of them but sounds interesting
Now another concern is with the SES on is my car going to run rich? I know when ever my Prelude used to throw a code (caused by the VTEC Controller) the car would burn fuel like a V8 untill I reset it.
Old Jan 6, 2010 | 07:35 PM
Sylvan lake V35's Avatar
I had them on test pipes no CELs ever.
Old Jan 6, 2010 | 09:03 PM
red35's Avatar
no i don't think it does that. Just a annoying light.
Old Jan 6, 2010 | 09:58 PM
bigc's Avatar
Wings Nation
what he said
Old Mar 8, 2010 | 10:45 AM
I'd like to pick these up now that the testpipes are going in, where would I buy these crappytire? UAP?
Old Mar 8, 2010 | 11:41 AM
So I went to partsource today to ask for these and the guy never heard of them. Where would I get these anti foulers?
Old Mar 8, 2010 | 07:08 PM
bigc's Avatar
Wings Nation
go to any Kragen / OReilly / Autozone / generic parts store and look for their 'HELP' display. The part you're looking for is a spark plug non fouler and if i remember correctly, you want the 18mm ones. They look like this:
Old Mar 8, 2010 | 07:20 PM
TIAN's Avatar
Hold The Line
I have those installed in mine and I still throw the light
Old Mar 9, 2010 | 06:36 PM
mint_g35's Avatar
i have test pipes and i had them on my car for over a year and no light
Old Mar 13, 2010 | 04:12 PM
Dr. Ephil's Avatar
It's hit or miss whether pipes will trip the SES light. The non-foulers are also known as o2 bungs.
I have F/I non-res pipes. First went with no bungs then short bungs and finally j-bungs to try and fix this with no luck. Tried wideband o2 sensors...no luck,still got SES light daily with codes for the right/left banks.
Had codes diagnosed and results showed the sensors thought the car was lean in #6 cyl so was adding 10% more fuel to compensate. I ended up buying a hand-held obd2 reader and clearing the memory every time I started my car.
Finally solved the problem yesterday...had an Osiris Uprev dyno tune done and while they were at it turned off all codes for both banks.
ps-luvin' the Uprev...on the Mustang(heartbreaker)dyno I only gained 10whp but got a whopping 36WTQ!!!
Old Mar 14, 2010 | 04:31 PM
I'll try to find them this week, I'm hopping Canadian tire will have them if not I'm not sure where else to look (in Canada)
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
