Canada Serving Canada.
N/A Engine mod enquiry
Old Feb 8, 2010 | 10:10 AM
ReD De(V)oN's Avatar
Originally Posted by 4DGS
But if you're going to go FI, build that engine too.
There is a local Z, can't remember whose it is. It's a shop car though, it makes 327hp N/A and the car hasn't seen a single problem.
I'd rather have a high hp N/A engine than a high HP FI where parts are more expensive to fix or replace (I.E. turbos)
I would have to agree. I would love to see that Z, next time i'm on your area you'll have to show me.
Old Feb 8, 2010 | 12:07 PM
Hossmaxima's Avatar
Go to SG Motorsports and get there long tube headers and increased MAf housing intake and you will be at 300whp.
Old Feb 8, 2010 | 01:48 PM
http://vimeo.com/8948049
http://www.youtube.com/watch?v=iU2h0JTq2fk
God damn that is impressive! VQ definitely has a lot of N/A potential. if you are talking about the system in the video I don't quite think they are producing the system, I am under the impression that they are just testing it.
Thanks Hoss
Old Feb 8, 2010 | 01:56 PM
Jeff92se's Avatar
Red Card Crew
Originally Posted by Sylvan Lake V35
Titans are 5.6L the new FX has a 5.0L and I think Frontiers/pathfinders have a 4.0L. When ever you swap an engine that was not intended for a vehicle it gets expensive due to the amount of custom parts/fabbing required not to mention you have to buy the new engine.
That all depends on how compatible the heads/timing chain/cover/VTC systems are inbetween the two. If they are direct bolt ons, then mixing/matching is alot easier. If the bottom end or the entire short block is swappable, then there's your 4.0 stroker right there. Just have to see if the lower/upper intakes etc.. can be converted etc.. Also have to see if the taller block will clear the hood.
For reference, people have been putting VQ3.0 heads onto VQ35 short blocks in maximas for years.
Old Feb 8, 2010 | 02:12 PM
Sylvan lake V35's Avatar
Wow that SG car idels horrible I would not want that on a street car at all, i have JWT C2 cams and my car idels way better than that. Also to use a LS2 Throttle body you will need a standalone EMS to change from electric throttle to a cable style.
So for head work+cams $3000minimum + EMS $3000 +Headers $2200+ LS2 Throttle body and install (it won't be a direct bolt in) $1000minimum +larger MAF $100?
So about $9300 and you have aprox 320whp
Twin turbo kits are around the same price $7000-9000 and Boosted Performances single turbo kit is aprox $5500 and you can get 400whp or more with a turbo kit. I ran 420whp on my JWT 530bb kit and I never had the slightest issue for over two years it was flawless.
Not trying to pee on anyones party, its just the reality of it. I wanted a sick NA build when i first started looking into things but the value wasn't there. Heads and cams are a huge expense however they are still useful if you were to go FI but for the money of heads, cams and install you could get a vortech SC or Boosted Perfs single turbo system both of witch can be install yourself.
Heads and cams are not an easy install in the car you basically have to tear the whole front end off your car to do it. Boosted Perf said his kit is less than 8hrs to install and you don't even need to change out the factory exhaust manis if you don't want to. I am not saying don't go NA just explaining the reality of it to you NA would still be a cool build, i was also looking at individual throttle bodies when I was planing to go NA they look crazy but were about $6000!!
Here is my car when i was just doing cams.
Drifter2090
Dec 26, 2015 12:10 AM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
linedr89
Aug 17, 2015 05:11 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
