Canada Serving Canada.
I think I need a second opinion...
Old Apr 2, 2010 | 08:39 AM
Coach's Avatar
I had a new set of Bridgestone RE960AS Pole Positions installed on my "05 Sedan yesterday. These tires aren't available in the OEM size of 215/55-17, so I went with 235/50-17. These have exactly the same diameter as stock, and are well within spec for the width of the wheels.
I asked the shop to do a wheel alignment at the same time, just in case the potholes had tweaked anything over the winter. When I picked it up, they told me that they couldn't guarantee the alignment because of the non-stock tire size. I think they're full of ****. Have any of you heard any reason that this might have some basis in fact?
Old Apr 2, 2010 | 08:55 AM
RBull's Avatar
Rated M
I think your hunch is right. IIRC the optional OE tire (aero / performance package) on the sedan was a 245 45 18 which would be even wider and about the same diameter. Would they not warrant the alignment if you had 18" wheels and that size tire?
Old Apr 2, 2010 | 09:02 AM
GEE35FX's Avatar
^^^What Deane said
Old Apr 2, 2010 | 09:05 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
+1
They're so full of it their eye's are brown.
Old Apr 2, 2010 | 09:18 AM
Swivel's Avatar
Moderator
Yep, weasel-words so they don't have to stand behind their work. I suppose if the car drives fine, you can just let it go, but then you have no recourse if your tires wear unevenly due to alignment issues. I suppose you could point out to them that you are running a standard size for your car and ask them to provide the guarantee.
EDIT: oh, and pretty chicken move to tell you AFTER the fact. Nice tires, btw!
Old Apr 2, 2010 | 10:00 AM
Chico's Avatar
the unfortunate reality is that there are a bunch of morons working at dealerships these days. I've had my alignment done many times at an INFINITI dealership (mod friendly) with my 19" wheels. I always ask for a before and after printout. Depending on the info, I keep an eye on my tires wear over time, and allows me to swap them left > right and right > left to get a more uniform wear.
Old Apr 2, 2010 | 04:31 PM
Coach's Avatar
Thanks guys, that's what i thought. It wasn't a dealership, it was a Bridgestone/Firestone shop. They gave me the printout (after I asked for it) and everything looks good there. I may be imagining things, but I think the steering wheel might be a little off center. I'll know better after the weekend.
If I have to I'll pay somebody else to align it again. Fargin' bastages.
Old Apr 3, 2010 | 03:40 PM
RBull's Avatar
Rated M
^they'll probably "warranty" the steering wheel being off center, since that's fundamental to start off at "12:00. With that and their initial reluctance to cover their it's understandable if you were to go elsewhere unless they're cooperative.
Old Apr 4, 2010 | 12:19 AM
Sylvan lake V35's Avatar
I run 265on the front and 305mm on the back and the shop stood behind my last alignment
G_Deprivation
Dec 12, 2013 08:50 PM
Loyali5t
Apr 10, 2010 09:33 AM
xCALiBUR05
Feb 3, 2010 08:52 PM
