Canada Serving Canada.
Running Lean
Old Jul 21, 2010 | 11:24 AM
GD-Up's Avatar
Running Lean
Hey all,
I need your thoughts on this.
Apparently the dealership said my car is running a little lean due to breather mods. (CAI/ Dual Exhaust/ Spacer)
Would those mods be sufficient to affect my A/F levels and why isn't my MAF adjusting for the changes?
That said what is the best way to fix this? I am assuming I will need a tune.
So what software and with who.
I was thinkng RCTS- Calgary, but is Lightspeed worth the drive?
Thanks!
Old Jul 21, 2010 | 12:33 PM
Sylvan lake V35's Avatar
Did you ask the dealership what your AFR was or how they knew it was lean?? These cars typically do run lean with breathing mods so maybe they are just throwing it out there based on that. My car ran lean I confirmed it with a wideband on the dyno but not lean enough to damage anything or even cause concern I even got an SAFC and leaned it out further. Typically there is power to be found in running lean, to an extent. MAFs only read air flow they can't change it. Your ECU can adjust but only so much, you are giving the car more air than it was designed to handle.
Where you are at mod wise I would say go to a dyno and do some base runs with a wideband and see if you have anything to actually worry about. Or get a COBB and reflash your ECU I think COBBs are worth $500+/- they come with a base tune or you can get a custom tune from a licenced COBB tuner.
As far as I know Reg (RTCS)only tunes F-cons (standalone ECU) that is not need with your mods and I know a few guys that use him but I don't know anyone that has a full tune they all seem to run only "base maps"
I am a Lightspeed customer and friend of the owner but personally I don't care if others use him or not. I always recommend him due to the fact he has at least 10x more experience with G35s than any other shop in Alberta and he tunes every ECU (he likes some better than others) under the sun. However good luck getting into get a tune he is booked for months in advance. You could buy a COBB from him put the base map in and go back later for a custom tune though. Another option would be a turboXS utec and anyone can tune it but they are more money and harder to install several members that have had them regret getting them and sell them and buy something different.
When I had similar mods CAI, Spacer and dual exhaust my car was on the lean side but not lean enough to cause concern I would bet yours is the same. Dealerships often talk out of their a$$es and have very little experince with aftermarket parts.
Old Jul 21, 2010 | 02:36 PM
audiophool's Avatar
Considering my changes, this thread is making me nervous...
Old Jul 21, 2010 | 05:54 PM
Not sure why It is well known that these cars run lean with any mods. If you add more air but do not add more fuel it will obviously be leaner than it came from factory. With minor mods it will likely not be lean enough to do any damage and if it dose lean out to much I think the factory ECU will pick up the knock and retard the timing. I have not been into N/A mods since 2006 now and even then I was researching FI mods and buying supporting mods for FI. N/A was never in my plan so i am not 100% sure on the factory ECU capability with knock detection and retarding timing but OEM usually do a fairly good job of keeping your engine safe. 1000s of people have the same mods most of you guys do and I have yet to hear of intake, spacer and exhaust cause a blown engine and like I said I leaned my car out further with an SAFC and I still never had any issues.
If you need peace of mind I think it is a few hundred bucks to get a few dyno pulls with an air fuel reading for peace of mind it might be worth it
Old Jul 21, 2010 | 06:07 PM
GD-Up's Avatar
Thanks for the info Gord!!
The only reason I am looking into this is i have had some idle issued previously, (looks like it was a bad ignition coil). But i am still having the car's idle drop at stop lights and hesitate. I'm going to clean the MAF again this weekend, but im not sure what else is causing this issue.
I didn't think that breather mods would cause me to run so lean the the car would just cut out!?
Old Jul 21, 2010 | 07:54 PM
forweareLegion's Avatar
Everyone who wants anything to do with NA needs to look up Sasha Holy Fvck's thread on Ziptied. The stock computer can compensate for quite a bit.
http://www.ziptied.com/forums/index.php?topic=15975.960
Read. ALL OF IT.
Shaun (sp?) I dont think that breather mods would be causing your idle issue. Likely something spark or vacuum related is unhappy.
Old Jul 21, 2010 | 09:12 PM
audiophool's Avatar
j/k, but I'll keep an eye on my fuel economy and watch for radical improvements (lol). Then perhaps an AWD dyno pull or two for kicks.
Old Jul 21, 2010 | 10:07 PM
GD-Up's Avatar
Thanks Hucker,
I've taken it to three shops (one being the dealership). I changed the plugs a couple months ago. One shop replaced an ignition coil. And no on spotted any leaks.
I am not sure what do do anymore..no one can seem to fix it. Just a bunch of expensive "try this" answers.
Old Jul 21, 2010 | 10:29 PM
350Z T's Avatar
At this point I would shy away from Cobb:
Originally Posted by COBB Tuning
COBB Tuning is announcing a restructuring of the AccessPORT product line in order to better align our internal resources with our core markets. Effective immediately, COBB Tuning is discontinuing development of AccessPORTs for the naturally aspirated Nissan 350Z and 370Z. Other naturally aspirated platforms affected by this restructuring include the Honda Civic Si, Infiniti G35 & G37, Mazda RX-8 and Subaru 2.5i & 2.5RS. Development for the Nissan GT-R is unaffected by this announcement. This refocus of resources and efforts will ensure that COBB Tuning can provide the high level of service each individual AccessPORT platform requires going forward.
This means that AccessPORT firmware, AccessTUNER (Pro and Race) software and Off-The-Shelf calibrations for the Nissan 350Z and 370Z have reached their final levels of development and customers may continue to use them in their current forms. AccessPORTs for the 350Z and 370Z will remain available for purchase for the next 30 days. AccessPORT hardware will remain under warranty 1 year from the date of purchase and repair services will remain available should your AccessPORT require service. COBB Off-The-Shelf maps and AccessTUNER software will remain available for download from the COBB Tuning website at their current version levels.
At COBB Tuning, we are committed to our customers' satisfaction with our products. In light of this change of product support, we are extending our AccessPORT Satisfaction Guarantee to 90-days from the date of purchase for the Nissan 350Z and extending it to 12 months for the Nissan 370Z. Please click on this link to learn more about our AccessPORT Satisfaction Guarantee.
If you have any questions or concerns regarding this announcement, or you wish to learn more about COBB Tuning products, please contact one of our Customer Service agents at 801.713.0035 or support@cobbtuning.com.
Old Jul 21, 2010 | 11:30 PM
Why would you shy away its not defective, just not profitable for COBB. I would buy one ASAP to be sure to get one. It is by far the best tuning solution availible in Alberta for NA cars.
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
Rhinos7777
Sep 6, 2015 05:36 PM
n2fooz
Sep 4, 2015 07:46 PM
