Canada Serving Canada.
VDC & SLip Light on
Old Sep 26, 2010 | 11:48 AM
e92_bj's Avatar
VDC & SLip Light on
New on the forum, hope i can get some help from you guys.
Last nite i drove my car on my way home all of a sudden the exclimation mark and the vdc and slip light turn on but the car drives fine.
But this morning when i went out the light is still on, I try pressing the button VDF but it won't turn off. The car drives the same, has any encounter that problem?
My car is 2004 G35
Hope some of you guys could help me out.
Thanks
Old Sep 26, 2010 | 12:55 PM
GEE35FX's Avatar
Check your brake fluid level, it could be down, and needs to be topped up.
Just remember, if the level is down, your brakes are probably getting worn, so they should be checked if you find this.
Old Sep 26, 2010 | 01:22 PM
RBull's Avatar
Rated M
^yeah, most likely brake fluid is a short term fix. Likely will need pads/rotors soon.
Old Sep 26, 2010 | 01:29 PM
nogoodname's Avatar
Originally Posted by gee35fx
check your brake fluid level, it could be down, and needs to be topped up.
+1!
Old Sep 26, 2010 | 05:49 PM
e92_bj's Avatar
Just check the brake fluid. It was low top it up the light is gone.
Thanks guys!
Old Sep 26, 2010 | 06:19 PM
GEE35FX's Avatar
^^^that's great, just make sure to check your brakes soon. As I said earlier, it is a warning sign that they are wearing down.
Old Sep 30, 2010 | 01:48 PM
theGster's Avatar
that happened to me a while back. i checked the fluids and all, but it was my ABS sensor in the rear. changed that and the lights were gone.
Old Oct 3, 2010 | 11:34 PM
e92_bj's Avatar
So I top up the fluid and the light went away for a few days. But those light came back out again, brake pad seems to be still good. There is a lot thread left.
Old Oct 3, 2010 | 11:49 PM
redpearl99's Avatar
isn't the exclamation looking light the low tire pressure sensor?
Old Oct 4, 2010 | 12:33 PM
RBull's Avatar
Rated M
^yes, by itself it is.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
