Canada Serving Canada.
Block Heater.. Is it worth it?
Old Oct 29, 2010 | 11:54 AM
akoustic's Avatar
I have a block heater installed from factory. I'm thinking of actually using it this year.
I am not sure if there are any down sides to using the block heater other than the fact that my electrical bill will go up.
Will there be some sort of negative effect to my engine or coolant or etc?
Old Oct 29, 2010 | 11:56 AM
audiophool's Avatar
You only need it for a couple of hours prior to starting and only when it's under -20. They're about 400 watts, so not a huge hit to your elec bill if used properly.
Old Oct 29, 2010 | 11:58 AM
LordFappington's Avatar
Just hook it up to a timer.
Old Oct 29, 2010 | 01:49 PM
35bills's Avatar
Here is some info from a previous post on block heaters... check it out.
https://g35driver.com/forums/canada/...-question.html
Old Oct 29, 2010 | 03:55 PM
redpearl99's Avatar
ive never heard of anyone complain about electricity use with their block heater
Old Oct 29, 2010 | 04:38 PM
1hotvq's Avatar
+1.
no negative effects at all.
Old Oct 29, 2010 | 10:08 PM
forweareLegion's Avatar
Power consumption goes up when you have 4 big *** diesel trucks plugged in at your shop.
You'll be fine.
Old Oct 30, 2010 | 09:27 AM
350Zed's Avatar
If you park outside, get one. Simple.
Old Oct 31, 2010 | 02:43 AM
Eno's Avatar
Eno
Nice chance for me to jump in here... Our call volume actually goes up measurably during the winter because of block heaters. Big reasons are because of continued wear on the block heater cord from being crammed between the hood and the body of your car. Wear out the insulation- and suddenly things become more unpredictable. Easy to avoid, but happens because of absent mindedness.
Also, on that note- those of you who warm up their vehicles in the garage... suffice to say I'll punch anyone in the face for warming up their car while it's parked in the garage.
Just don't do it.
Old Oct 31, 2010 | 05:34 PM
msommers's Avatar
I checked my car this morning and I couldn't find a plug. I thought all cars in Canada came with a block heater?
Old Oct 31, 2010 | 05:36 PM
akoustic's Avatar
it's an option. you will see a plug on the driver side grill if you have the option.
Old Oct 31, 2010 | 05:45 PM
RBull's Avatar
Rated M
It's standard equipment for CDN cars. You may have to search for the wire and plug but it's there.
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Visionnn
Oct 3, 2015 05:16 AM
B03Sedan
Sep 22, 2015 10:37 PM
