Canada Serving Canada.
PO boogered up my clutch
Old Jul 25, 2011 | 08:47 PM
audiophool's Avatar
I picked up the G37S 6MT last September and have been coping with a juddering clutch since the get go. On hot, humid days the juddering is nigh on uncontrollable so something has to change. This car is US and only has 40,000 miles on the clock.
Since I'm going to open it up for a new disk, PP and flywheel machining (or whatever is involved (dual mass on these ), any suggestions to go other than OE parts? I have no plans to boost power, nor do I drive really aggressively (much...), so thoughts on aftermarket parts known for smoothness?
TIA
Old Jul 25, 2011 | 09:00 PM
redpearl99's Avatar
if you want smoothness then go with OEM. nothing else really comes close
Old Jul 25, 2011 | 09:51 PM
forweareLegion's Avatar
First and formost; lightweight flywheel. **** the useless dual mass. Theres a lot of good performance clutches out there that drive like stock. My previous OS Giken & ORC multiplate units drove just as good if not better than oem junk. And they held up to a never ending torrent of abuse.
Old Jul 25, 2011 | 11:36 PM
redpearl99's Avatar
if you want performance then go with a lightweight flywheel. But it's gonna sound like **** compared to the dualmass OEM. if you want smoothness and your car is a DD then go OEM.
Old Jul 25, 2011 | 11:47 PM
A decent single mass flywheel paired with a good 'stage 1' clutch will give you factory drivability with some mild performance gains when you feel like driving like a weiner. If you think the noise could have negative effect on your ears just go stock for stock.
Old Jul 25, 2011 | 11:52 PM
audiophool's Avatar
I like the idea of a lighter flywheel - free up some power at the minor expense of smoothness. I won't go as far as an alumininium flywheel though. This car is way too smooth and quiet now...
Oh, and I'll be doing the work myself. No way I'm paying shop rates.
Old Jul 26, 2011 | 12:45 AM
No doubt. No need to gouge your pockets. Theres a lot of options for cro mo flywheels out there.
JWT makes a nice unit, almost halves the stock flywheel weight. I have no idea what its made from though haha.
Old Jul 26, 2011 | 12:59 AM
Sylvan lake V35's Avatar
Jim Wolf or a USDM Nismo single plate they will be lighter than stock but with similar to OEM drivability. Both are high quality I would go with the cheaper of the two. I know Lightspeed is a JWT dealer Nismo you can get through any Nissan dealer, I would also have it installed where you buy it.
Old Jul 26, 2011 | 10:51 PM
ScreaminG's Avatar
I just put in a new clutch kit from GRIPFORCE (Exedy clutch kit+F1 flywheel) with lightened flywheel in place of the dual mass. When getting the car moving you are gonna get some chatter noise, otherwise my knees are thanking me daily...
Flywheel (F1 racing) is 18lbs, down from 31lbs. Made from 4140 forged chromoly steel (2X stronger than billet steel).
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
jbmw002
Sep 10, 2015 12:54 AM
