Canada Serving Canada.
Scammed By Downtown Infiniti
Old Oct 25, 2011 | 01:53 PM
Hotdawwgman's Avatar
Whoa. Someone needs to get to the bottom of this...
well from my experience with paint.... My cars headlights have been hazed due to the paint booth, they do set a heater on to about 120 degrees to evap all of the humidity out of the booth just to paint. It is quite possible for the headlights to turn colors... i am not saying that it did do that, but I just wanted to confirm that it is possible... i was able to get the shop to buff the headlights.. regardless I just need to buy new housings!
Old Oct 25, 2011 | 02:23 PM
Pepper's Avatar
Originally Posted by 4DGS
Hate to break it you, but those are the same lights. When a car gets painted (especially the full side of it or 2...) they need to bake the whole car in the oven. 90% of the time they do it the headlights oxidize. Another thing could be that you had wax on the light and the wax has baked itself dry and damaged the lens.
BUT, I could be wrong but so could you. So before you slander a businesses name you might want to figure out exactly what happened.
Go get them buffed and see what happens.
Regardless of the reason, the headlights were NOT returned in the condition they were given. The dealer should eat the bill on buffing (only if it removes the issue %100) or replacing them. My car has been in a booth and I didn't have an issue with my lights. People who have had their roof painted should chime in.
Old Oct 25, 2011 | 02:34 PM
Roof painted?? I had my whole car repainted... maybe that could be the difference!
Old Oct 25, 2011 | 02:38 PM
forweareLegion's Avatar
Originally Posted by Texasscout
No body has "baked" paint since the early 60's. Almost all automotive paint is now a two part (paint base and hardener).
Then why did the shop I worked at crank the heat in the booth after finish.... 'baked' is a term that could be loosely applied in modern autobody.
Old Oct 25, 2011 | 03:04 PM
4DGS's Avatar
I've work very closely with my paint shop, they are the best within a 100k and they BAKE every car after being painted.
Hardeners are not they're own catalyst they are either an oxygen or heat catalyst. Majority being the latter. If your shop doesn't have a gravity booth with a built in oven then your paint probably looks like ****.
BTW, Texas, you're spending an awful lot of time in the Canadian section lately. Planning a move? lol
Old Oct 25, 2011 | 03:15 PM
jarvo's Avatar
^ I'd assume he clicks Get New...Thats how I found this. https://g35driver.com/forums/search.php?do=getnew
Old Oct 25, 2011 | 04:09 PM
4DGS's Avatar
Ahh true enough, I never use that. I just use the sub sections and roam around.
Old Oct 25, 2011 | 04:12 PM
rpm&my_G35's Avatar
I use 'New Posts' all the time but still look in the right hand column first (forum), especially if I'm gonna comment.
OP - I sure hope you get those lights taken care of. G/L
Old Oct 25, 2011 | 04:19 PM
sdnpaul5at's Avatar
It's frustrating, this may take a while to get roselved. I added a pic to show how the lens is actually cracked. So when I picked up my car the other day, I said to the owner "so you're returning my car back to me with cracked headlights"? His response was "YES" I was floored!
Old Oct 25, 2011 | 04:48 PM
surfjax87's Avatar
Did you sign off for the warranty work completed when you went to pick it up? I'm hoping you didn't. Refuse to take delivery of the car until this is resolved. Once it's back in your hands, you have less room for negotiation. Definitely pursue Infiniti corporate and whatever the BBB equivalent is in Canada.
Old Oct 25, 2011 | 07:49 PM
kingrukus's Avatar
Wow... just wow. I really hope you end up getting a set of new headlamps out of this.
Old Oct 26, 2011 | 09:14 AM
CDN_G35's Avatar
I'm sorry but this is so far from the truth. I work at a automotive plant in the paint repair department and we "BAKE" paint every day. I'm not trying to hack you up or anything but its best to get some facts straight before offering advice
To the OP, chances are those MAY be your original headlights. When they repair a vehicle nowadays they have high tech booths that double as spray booths and ovens as well. Chances are they didn't mask/protect your headlights properly and they heat has caused them to oxidize/crack. Its basically just being lazy and taking shortcuts, which seems all too familiar with this particular Infiniti dealer. Hope everything works out for you
Old Oct 26, 2011 | 09:41 AM
Swivel's Avatar
Moderator
Even if they are the same headlights, just oxidized for whatever reason, they should polish them up for you, no questions asked. Should have been done before it left the shop.
Old Oct 26, 2011 | 10:08 AM
Texasscout's Avatar
Yeah, it's to God Damn hot here....
Old Oct 26, 2011 | 10:16 AM
  #30
CDN_G35's Avatar
Completely agree.. That should never leave ANY shop like that! Especially an Infiniti dealer.. They need to pull up their socks.
