Canada Serving Canada.
build thread
Old Nov 8, 2014 | 03:52 PM
ge35es's Avatar
build thread
Ive just purchased a Vortech full kit for my G
I plan on making few changes to it when I install it
1) instead of the blocked location for the A/A intercooler i will be using an air to water unit
2) instead of the aux fuel pump i will put in a Walboro
to be continued
Old Nov 9, 2014 | 11:07 AM
whatacar's Avatar
Pics would be nice. GL with the build.
Old Nov 13, 2014 | 06:03 AM
ge35es's Avatar
the kit will arrive in a week or so
Old Nov 18, 2014 | 07:56 PM
ge35es's Avatar
just got word from my supplier that the kit is in their warehouse and should be in the GTA by Thursday or so
Old Nov 18, 2014 | 08:06 PM
DigitalDeviant's Avatar
Good luck with the build. Mine is also underway. Muhahaha
Old Nov 30, 2014 | 07:21 PM
ge35es's Avatar
Ive received my vortech non revup complete kit and everything is there and I have questions
1) reviewing the instructions i don't see anything about assembling the cog belt idler pulley so any pics or diagrams would be greatly appreciated
2) i have the Paxton black box as mentioned i the instructions P# 5A001-353 BUT...
I also received a larg black carton labeled Unidchip with a hand written sticker 5A003-350 containing a Q+ 0148D silver device and a slighty larger black device with no real model number except it has unichip PNP technology. There is nothing about the unichip boxes in the instructions but they themselves came with instructions.
do i use both systems ? or just one of them ?
Old Jan 1, 2015 | 01:01 PM
ge35es's Avatar
checking my parts list and checking it twice
Old Apr 2, 2015 | 04:30 PM
ge35es's Avatar
step 1) checked all the parts against the supplied inst sheets
turns out i had the wrong fuel pressure regulator.... it was resolved quickly by DaSilva Racing and Vortech
step 2) - 2 hrs - installed the "black box" aka the fuel and spark control unit
Most of the diagrams etc were correct. the pic dosent show the addl fuse box that my car has but, other than mis reading the orientation of the ecm plug pin out, it went smoothly.
I took the extra time to solder and heat shrink all the connections.
I didnt attach the vacuum hose
the car started and ran fine once it "found itself" (I had disconnected the battery)
Old Apr 3, 2015 | 07:10 PM
ge35es's Avatar
vortech aux fuel pump - new location
installed the fuel pump today... took 2 hrs because i want it high and dry and easy to trouble shoot and easier to visually check
i hope to locate the fmu in the same area
Old Apr 6, 2015 | 11:09 AM
whatacar's Avatar
Lookin good.
Old Apr 12, 2015 | 11:29 AM
ge35es's Avatar
B
stereo/HVAC finally kicked the bucket so this was a necessary purchase lol
crutchfield canada around $200 delivered next day
Old Apr 13, 2015 | 06:25 PM
ge35es's Avatar
spent 3 hrs today
I fought with the tubing from the throttle body to the inter cooler
nothing lines up
i finally got it to fit... sorta...
then i fought with the main bracket
the large longer bolt supplied doesn't seem long enough... and the toothed jack shaft pulley is really close to the piping
Old Apr 24, 2015 | 09:03 AM
ge35es's Avatar
ok shes almost done !
added guages in the center console
Old Apr 24, 2015 | 09:05 AM
ge35es's Avatar
driving impressions...
OMFGGGGGGGG !
ouch the BPV is way too loud
Old Apr 24, 2015 | 09:07 AM
ge35es's Avatar
swapped in a Bosch recycling valve instead of the BPV that comes in the kit...
now its dead quiet till i shift under boost... then its makes a soft whoosh that is barely noticible... LOVE IT
