Canada Serving Canada.
Oil Analysis
Old Apr 20, 2005 | 09:42 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by G35 6MT
I agree, lets compare! I'll start with mine.
My last oil analyst on the G, turned up some interesting results. They were all screwed up because I didn't have the engine at operating temp, so it showed 1.3% fuel contamination. ........
Do you mean you were running too cool?
Thermostat issues??
Or just not at operating temp when you took the sample.
Old Apr 20, 2005 | 10:02 AM
Zat_Zuma's Avatar
Originally Posted by inTgr8r
Do you mean you were running to cool?
Thermostat issues??
LOL ....sorry. I meant that the engine was not at operating temp when I changed the oil. I just moved the car quickly in the garage and then changed the oil. Next time I'll either let the car sit overnight in a position that I can change the oil or run it till hot and then change the oil.
Old Apr 20, 2005 | 02:04 PM
Msedanman's Avatar
O.F. Administrator
Wow, There's a good example of what short distance driving will do to the oil.
I'm amazed that just moving the car would have that effect.
I can see how bad consistent short trips would be.
C.
Old Apr 20, 2005 | 03:19 PM
InTgr8r's Avatar
Thanks that makes more sense.
FWIW..
I have see others recommend the hot method.
They contend that you get a better flush that way,
with the solids more in suspension rather than lying cold on
the bottom of the oil pan
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
