Opening door in the Winter
As you all know, we don't have frames for our Window/Door. This morning when I opened the door (minus 4 outside), it was really tight. The moisture from over night must have froze so the window/door felt like it was going to shatter.
My previous WRX had the same design (no frame around the window) but I never had problems opening the door. Anyone else experience this? How did you battle it? Put some sort of grease along the rubber edge?
In my previous car, silicone spray (not sealant) did help... but with heavy ice buildup it would still stick sometimes. A friend recommended putting a small amount of petroleum jelly on a rag and then wiping down the seals which worked better.
Originally Posted by 35bills
Wouldn't petroleum jelly tend to break down the rubber over time?
The best thing would be a product that's available from your local BMW dealer called "Gummi Pflege"..... It's a rubber protectant/lubricant that is meant for this task and comes highly recommended.
C.
I don't use Amour-All for anything else- except for the rubber seals on the door, trunk, etc.
I've used the stuff this way for about 20 years and it seems to work for me, and is fine for the rubber.
Haven't visited the board in awhile....
I think the best protectant out there is 303 Aerospace Protectant. I asked my independent BMW shop about Gummi Pflege once, and the owner did not recommend it for regular protection (I don't recall exact reason -- maybe too messy?)
303 Aerospace provides the best protection for rubber/vinyl/plastics/etc...
Check 303 site for info:
www.303products.com/main.php?infopage=protectant
It's widely recommended by many corporations.
I use it on weather seals, and put it on my summer/winter tires before I store them. I also use occassionally as tire dressing (if you like glossy look, 303 isn't glossy -- it just makes rubber look new).
Used to be sort of hard to find in Canada. Now it's widely available, including at Canadian Tire.
Originally Posted by Pearl Necklace
Every winter, I clean the rubber and spray some Silicone Spray from Canadian Tire (the can with the red cap). Seems to have worked well for me over the years.
Oh, Welcome to the Board Will
Wayne
C.
