Canada Serving Canada.
Coupe is stalling a bit...anyone else?
Old Feb 25, 2006 | 10:44 AM
BurntRenolds's Avatar
Anyone else find that after driving for a while...if you turn off your car, pop into a store and turn on your car again...the car has difficulty starting?
I've been to the dealership a few times to correct this but nothing...
2003 coupe with about 65000K
Old Feb 25, 2006 | 11:04 AM
2FastG354U's Avatar
Some major miles were put on that car... I haven't heard of that problem before either... What does your dealership say??
Old Feb 25, 2006 | 11:25 AM
G35_TX's Avatar
Any mods?
Old Feb 25, 2006 | 12:42 PM
35bills's Avatar
Its Canada!!! 65000 Kilometers!!!
Old Feb 25, 2006 | 12:50 PM
Msedanman's Avatar
O.F. Administrator
With that kind of mileage, you're due for a throttle body and injector cleaning.
I'll bet that fixes your problem.
C.
Old Feb 25, 2006 | 01:42 PM
RBull's Avatar
Rated M
+1^
Old Feb 25, 2006 | 07:22 PM
what's a throttle body?
Old Feb 25, 2006 | 07:30 PM
avs007's Avatar
If I didn't know any better, I'd think that your injectors are bad, and are leaking fuel into the combustion chamber when you shut it down, such that your engine is flooded when you try to restart.
A leakdown test should determine if that is the case or not.
Old Feb 26, 2006 | 01:06 AM
thanks...I'll tell the dealership to check that out for me...
Old Feb 26, 2006 | 09:22 AM
Msedanman's Avatar
O.F. Administrator
It's an air metering device in our intakes that needs service occasionally due to dirt buildup.
If you've ever taken your inlet tube off to put on a Z-tube, you can see it quite plainly at the rear of the upper plenum. It gradually turns black with dirt.
G/L with repairs
C.
Muski_G
Dec 1, 2023 11:11 AM
Terry_G35
May 9, 2020 01:39 AM
Wayne9011
Aug 17, 2015 01:24 AM
Terry_G35
Aug 4, 2015 02:38 PM
Wayne9011
Jul 27, 2015 11:25 AM
