Canada Serving Canada.
2006 Light housing for 2005 and earlier models
Old Oct 23, 2007 | 04:14 PM
  #61
God|ZIlla168's Avatar
Sorry folks I never got to finish this mod I did half of it and the rest I gave the guy who original provided me with the wiring diagram and how to. My lights are working properly.
Old Oct 23, 2007 | 04:15 PM
  #62
ONEmike's Avatar
I completed this mod its pretty tedious although i didn't take any pictures while doing it. If anyone in the GTA needs this done you can PM me
Edit: For my lights i did everything so it works 100% percent along with DRL's I also ended up doing a few custom things to the lights
Old Oct 23, 2007 | 04:21 PM
  #63
hey are you good with the solder? I need someone to solder one of the wiring because is a little loose.
Old Oct 23, 2007 | 04:24 PM
  #64
ONEmike's Avatar
Heres a link to the thread of my headlights
Custom Headlights
Yah im pretty good with the solder although i need to pick up a new one becaue my other one is old and worn out
Old Jan 28, 2008 | 09:45 AM
  #65
specialist's Avatar
there is a h1 for the high beams?
I am going to try to attempt to install the relays for the drl. i will take pics. I hope this wire diagrams works also that i hope it understand it by looking at it. i can make out most of it out
Old Jan 29, 2008 | 03:42 PM
  #66
ONEmike's Avatar
H1 isn't the high beams the projector acts as your High beams by using a sheild.
On a side note i rear ended a van 2 weeks after i installed my lights and ended up cracking one of the lights but i am installing a bunch of parts including a new set of lights
Old Feb 6, 2008 | 10:19 AM
  #67
specialist's Avatar
I have done the mod. But i don't know if it is working right.
High beams work
fog lights work
signal work
dlr work
I want the signal to keep on when it is not in use.
Old Feb 6, 2008 | 12:54 PM
  #68
G35Sask's Avatar
I managed to blunder my way through the conversion as well.. The only thing not working is my DRL's and I don't know why. I am just going to pull the fuse and call it good.
Old Feb 7, 2008 | 12:20 PM
  #69
specialist's Avatar
did you cut pin 1 2 and hook up wires that are going to light not from harness from relay #30 from both relays to them
Old Feb 11, 2008 | 12:53 PM
  #70
specialist's Avatar
I just realized that when i put to auto it will not shut off any one have this probelm
Old Feb 12, 2008 | 12:22 AM
  #71
G35Sask's Avatar
my drls are my only problem thus far.. I hope pulling the fuse will make it ok.
Old Feb 12, 2008 | 03:29 PM
  #72
specialist's Avatar
if you need help i can help you just pm and i will give you my msn
Old Feb 14, 2008 | 08:58 PM
  #73
zx10r_646's Avatar
Guys,
I don't visit the regional forum very much... I am surprised to learn that people are still having difficulty with this mod.
If you are not use to reading an electrical schematic, them I would recommend that you take it to your local auto stereo installation shop. They should be able to help you... and it should take you at most 2 hrs (if you are **** about how you make the mods).
I will try answer any questions but it is very difficult to explain over messenger/telephone if you are not familiar with cutting, stripping and soldering wires.
For those of you in Ottawa, I can mod your headlings for you.
Good luck
Larry
Old Apr 8, 2008 | 04:16 PM
  #74
tegernaut's Avatar
so did anyone other than godzilla and larry make a sucessful conversion with everything working?
Old Aug 31, 2008 | 10:43 AM
  #75
elrooko's Avatar
Hey guys - I have 06 projector headlights and happen to live 2 minutes from Larry's house. I'm getting together with him next week and I'll put up a complete DIY for this mod.
