Dracov's CarPC. Stock Navi replacement DIY. Status: in Progress
Old Oct 2, 2010 | 06:22 PM
  #76
MJP_24's Avatar
do the stock nav controls work on the aftermarket screen?
Old Oct 3, 2010 | 10:27 AM
  #77
nyqueenz's Avatar
Originally Posted by thehump
nice job NYQeenz... i read up on the manuals... does this actually have a VGA input that you can connect a carputer up to? and if so, does it have USB to hook up to the carputer with? what are you using as your video source?
i believe it has the av connects which i needed for the HKS Camp2.. it plugs to a module everything it comes with is in the above post. Oh it also hase bult in back up cam too.
Old Oct 3, 2010 | 12:58 PM
  #78
atmel101's Avatar
Nyqueenz where did you mount the black av box?
Also did u keep the internal speaker that comes with the alpine?
Old Oct 3, 2010 | 01:31 PM
  #79
nyqueenz's Avatar
Its gonna go inside the dash along with the camp2 harness and box. I dont know if the internal speaker is still attached prob is.. i had this shop doing in GA do all the work for me.
Old Oct 3, 2010 | 01:44 PM
  #80
atmel101's Avatar
so I guess you won't be able to answer my next question but maybe you watched the guys at the shop closely.
based on your earlier post I can see that you need to remove the film from the chrome housing right? is there clips or screws or did they have to cut?
Lastly, once the film was removed how did they install it in the oem housing? is there some type of frame that remains with the film after you remove the alpine housing?
thanks for all your help
Old Oct 5, 2010 | 11:40 PM
  #81
thehump's Avatar
if you are addressing me, no they dont and no plan to hook them up.
Old Oct 9, 2010 | 10:26 PM
  #82
nyqueenz's Avatar
the protective film wasn't removed because it links the touch screen to the device. only thing that was taking apart was the housing so it could fit flush inside the HD unit display casing. I don't have all the detail because this was done while I was overseas however, if you like the results and thinking about going this route I can put you in touch with the shop where I got the work done at.
Old Dec 29, 2010 | 08:25 PM
  #83
atmel101's Avatar
bought a xenarc touchscreen, I think I will give it a shot.
This is the ultimate setup, don't know why more people don't give this setup a shot.
Old Dec 29, 2010 | 08:35 PM
  #84
nyqueenz's Avatar
do it bro, u will be happy in the end.
Old Jan 8, 2011 | 07:28 PM
  #85
blAk mAx's Avatar
2011 !
Old Jan 8, 2011 | 08:10 PM
  #86
blAk mAx's Avatar
theres been a break in the case!
http://www.chicagoz.com/forums/showthread.php?t=20583
Old Jul 25, 2011 | 01:08 AM
  #87
samag35's Avatar
anybody saw this yet ? It is a module that lets you duplicate an iphone screen on to a larger resistive touch screen; given that your iphone is jailbroken
https://store.mp3car.com/ProductDeta...e=MimicsModule
the module is suppose to work with a standard Lilliput 7" 4-wire resistive touch screen monitor
http://store.mp3car.com/Lilliput_669..._p/mon-124.htm
would this possibly fit in the 05 stock pop up housing?
Old Aug 2, 2011 | 09:29 PM
  #88
blAk mAx's Avatar
Old Jul 14, 2012 | 10:00 AM
  #89
DesStar's Avatar
Would this work with a tablet also? Also if you go somewhere and want to disconnect the computer it would not have any issues being reconnected?
Old Jan 26, 2013 | 09:50 PM
  #90
silver565's Avatar
I think this is fantastic, the only question I have.. is how did you get it to stay up?
EPG35
Aug 16, 2015 04:52 PM
Jussaku
Aug 4, 2015 12:45 PM
Frostbite91
Aug 2, 2015 04:59 PM
CJay
Aug 1, 2015 03:57 AM
