Removed badges - still see 'shadows'
Old May 20, 2006 | 09:06 PM
johnbigbootie's Avatar
Angry Removed badges - still see 'shadows'
So after much reading I went ahead and removed the 'INFINITI' and 'G35' badges on my Coupe (left the Infiniti logo in place). Per all I read, I used dental floss to carefully remove each letter, then used goo-gone on a Q-Tip to soak each piece of leftover adhesive. It all came out pretty good in terms of no scratches etc. I washed the deck lid then waxed the area where I removed the badges. I could still see where the letters were. I noticed that some letter lines still had a small amount of adhesive, so I went back over each one with Q-Tip and goo-gone. That looked a little better but still can see faint remnants of the letters. So I tried Scratch-X over the area, then another coat of wax. Still see faint outline/shadow where the letters were. Any ideas? I'm bummed 'cause I see a bunch of people here did this and said it came out "perfect"...
Old May 20, 2006 | 09:11 PM
mynismoG35's Avatar
try to go over it with some gas
Old May 20, 2006 | 09:29 PM
6MTzer's Avatar
Skip the q-tip for one thing, put that stuff on a soft cloth and rub.
I had a shadow after removing the side molding and it took three wax applications to get rid of it.
Old May 20, 2006 | 09:51 PM
Picus's Avatar
Staff ALUMNI
Time will take care of it. If you're in a hurry you need a more abrasive polish, but that can be difficult to break down by hand. Try ScratchX a few more times.
Old May 20, 2006 | 09:59 PM
maxpower's Avatar
after goo gone I washed the area and used klasse aio....no shadows...then a few coats ot fmj
Old May 20, 2006 | 10:27 PM
arjunz's Avatar
Dont worry bro .... just wait a couple days ..and u will never see it .. it takes time...
Old May 20, 2006 | 11:32 PM
thanks everyone for the responses, I do appreciate it! Worse comes to worst I can always glue them back on...but I do like the clean no badge look. I'll keep workin' on it.
Old May 20, 2006 | 11:43 PM
vrsc's Avatar
+1
Old May 21, 2006 | 10:36 PM
neal540's Avatar
just rub it down a couple of times with scratch X then use klasse AIO and finalllllllly put some wax on it. it'll go away then.
Old May 21, 2006 | 11:45 PM
hai109's Avatar
I used paint thinner...Then washed it and then waxed it a million times....okay just 3 times after that but it looked good..
Old May 21, 2006 | 11:55 PM
FortyTwo's Avatar
Does your car spend a lot of time in the sun? Over time the paint will change colors slightly, but it seems like it would take a lot for an '04. Not impossible, though. The sun should even it out over time.
Old Jul 21, 2006 | 05:45 PM
jimgpark's Avatar
I think it was the sun. I had the same problem with the G35 emblem - there was always an imprint of it on the trunk.
Getting rear-ended by an SUV fixed the imprint for me.
Old Jul 21, 2006 | 10:43 PM
jameyb's Avatar
I had the shadowing as well, it went away after a few more washes and waxes. Now it looks perfect, just give it some time.
No worries.
Old Jul 27, 2006 | 10:25 PM
ac419's Avatar
a little goo gone and wax after will be just like new
Old Jul 27, 2006 | 10:26 PM
ttrank's Avatar
Grocery getter
If you get it buffed it will be gone.
