Wheel cleaner
Old May 23, 2006 | 08:03 AM
Sugardaddy's Avatar
Wheel cleaner
What is the best way to clean wheels? In the past I have always used a brush with the spray on cleaner. Is this too harsh to do on a regular basis? I just have the stock 17" wheels on my G. Thanks.
Old May 23, 2006 | 08:31 AM
Picus's Avatar
Staff ALUMNI
Non-acid based cleaners are fine on a regular basis. There are a number of good ones. That said it might be beneficial to try some wheel sealant on your wheels which would allow you to clean them more easily in the future (I use soap and water on mine). Poorboys makes an excellent wheel sealant that is available online for under $20.00.
Old May 23, 2006 | 11:18 AM
GTScott's Avatar
The only thing I would add to the wheel sealant comment is that a light polish prior to the sealant appears to help the adhesion. I use Klasse AIO prior to applying the wheel sealant and have had great results. I also put on a few coats just to get 100% coverage.
As far as an actualy cleaner, I use a spray bottle with water and a wet microfiber and don't usually need much else.
-GT
Old May 23, 2006 | 07:14 PM
Mr. Wonderful's Avatar
I put on Wheel Wax, and my wheels have stayed much cleaner with it.
Also, dirt washes off easier too. Noticeable improvement.
Old May 24, 2006 | 11:15 PM
PhatG35x's Avatar
Wheel Wax
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
Frostbite91
Aug 12, 2015 05:16 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Tylerttn
Jul 16, 2015 10:33 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
