Jacks and Jack Stands
Old Aug 5, 2006 | 02:57 PM
mpspeer's Avatar
Patrick
I'm not sure where this post should go, but I think it's here. I am in the market for a Jack and 4 Jack stands. I was wondering what you guys use and if you like them. I found a 3k lbs. racing jack on Harbor freight for pretty cheap, But I was wondering what you all use... and What kind or what capacity jack stands do you all like?
Old Aug 5, 2006 | 07:30 PM
Mr. Wonderful's Avatar
Costco has a great aluminum jack for $89. I bought it when it was $99.
Old Aug 6, 2006 | 12:20 AM
x7original4x's Avatar
i read that you need a hockey puck or some wood to make the stand work....am i correct?
Old Aug 6, 2006 | 02:19 PM
OH6 G35's Avatar
Old Aug 12, 2006 | 07:56 PM
Here is a SIDE LIFT JACK PAD made of plastic which will do the job.
But you sure don't want to buy 4 at that price:
https://69.20.111.53/index.asp?PageA...OD&ProdID=1792
Old Aug 12, 2006 | 08:13 PM
speedracerg35's Avatar
just got an all aluminum low profile craftsman jack. 2 ton capacity which is not much, but had one pump riser (one pump of the handle lifts the jack up to the lift point. as far as jack stands go, go heavy duty and reliable name. you never want to be sorry that you didn't spend the extra $50 while your car is sitting on the ground.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old Sep 7, 2006 | 12:10 AM
avs007's Avatar
I got an Omega 3 ton Air-actuated hydraulic floor jack. (Can still hand operate the jack if necessary) It works awesome.. I just connect it to my air-compressor, squeeze the valve, pft, pft, pft, and the car raises up 19" in seconds...
I got it because my regular floor jack barely cleared my car. So I had to use a screwdriver to pump the jack, which not only takes forever, but is very hard with such little leverage.
Granted, my shiny air jack is a shade too tall to clear my G35, but I back my car onto a piece of scrap 2x4, and it clears fine.
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
TNRocker
Sep 21, 2015 08:36 AM
toadfire
Sep 21, 2015 07:15 AM
