is a flexible backing necesary...
Old Aug 24, 2006 | 10:48 PM
driguez's Avatar
like the title says is it really necesary to use a flexible backing with a rotary using a *foam* pad??
Old Aug 24, 2006 | 11:06 PM
badtziscool's Avatar
it's not necessary but it will help avoid hot spots and burned paint. Plus it will let you cover the curves more effectively.
Old Aug 24, 2006 | 11:31 PM
driguez's Avatar
well i ordered it, was only $20 so better be safe... thanx badtz
Old Aug 25, 2006 | 11:10 AM
G35stilez's Avatar
Concours d'Elegance
I've used both...VERY worth it to get a flexible backing plate.
Old Aug 26, 2006 | 10:11 AM
LMG_35C's Avatar
Unless you're doing refinishing of the paint like orange peel removal I'd use a flexible backing plate that is smaller than the PAD. It will save you a lot of grief if you run the pad / plate into some areas of the body contour that the rigid PAD would otherwise hurt.
Besides being safer, I also think it's a lot easier to work with.
Either way - not too much pressure on the PAD, let the machine spin the PAD rather freely.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
apintojr
Jul 23, 2015 10:52 AM
