Washing Wheels/Wheel Wells, rust concerns?
Old Sep 2, 2006 | 02:18 AM
Bobalude's Avatar
Wondering if there should be any concerns about rust when washing the wheels and wheel well area on the G?
Is it ok to spray water directly into the wheels and wheel well area? or is there some precautions/method to wash the area to avoid rust?
-edit-
I'm referring to all the suspension and brake parts down there that get splashed w/ water if a hose is turned on it... Control arms, joints, springs, struts, brake parts, etc
Old Sep 3, 2006 | 08:20 PM
Greeknasty's Avatar
uhh i would sure hope tehy dont rust
Old Sep 4, 2006 | 12:49 PM
HokieZ's Avatar
Uhm, dude, when you're hauling down the interstate at 80mph in the rain with dirt, rocks, dead animals and got knows what else bouncing around in the wheel wells, and you're worried about spraying some clean water up there causing rust?
Old Sep 4, 2006 | 12:58 PM
gary c's Avatar
Time for a bath.............
Don't concern yourself with rust under your car.
Buy a good wheel cleaner and follow the instructions.
I wash my wheel wells with dishwashing detergent
and a scrub brush then a power wash with water.
Enjoy...........LOL
Old Sep 4, 2006 | 03:28 PM
soaped's Avatar
I've used a pressure washer in my wheel wells and under my car for the past 4 years. No rust yet!
Old Sep 4, 2006 | 04:12 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
what? no rust?
to properly clean your wheel well, you need to get the car on four jack stands and remove each wheel.
using a scotch scuff pad, scuff each suspension component to free it of dirt and grime. than using a specially prepared solution of olive oil and high quality filtered Brita water, bath the pieces. olive oil helps prevent grime build-up.
DO NOT spray it with water. rust is inevitable, all you're dooing with the olive oil is prolonging the components lifetime.
best of luck.
Old Sep 12, 2006 | 08:33 AM
G35stilez's Avatar
Concours d'Elegance
Enjoy...........LOL
I do something similar. Just hose down the wells, soak in a cleaner (dawn mixed in a bottle with water is fine, or a wheel cleaner). Agitate with a wand brush and or brush/mf towel. Rinse clean, and either air dry or wipedown.
Follow up with a standard dressing. I prefer something like CD-2 Engine Detailer or Zaino Z16 due to their increased durability.
Old Sep 12, 2006 | 09:20 AM
GTScott's Avatar
Sorry to veer off track...but you seem to have experience with the CD-2 cleaner. I have some but have not gotten around to using it. From the instructions, it sounded like it was more of a product that actually dried unlike a standard silicone based dressing. Is this correct or can I spray it and then spread it around if needed?
Do you use it under the hood as well?
I have been using whatever is cheap for the wheel wells on my Yukon lately. Maybe it is time to swap.
-GT
Xfactor
Dec 1, 2019 12:52 PM
Nicksims13
Oct 15, 2015 01:57 AM
newg37
Jul 26, 2015 09:32 AM
