clay bar stracthed my car!!
Old Sep 14, 2006 | 02:52 AM
gotxstyo's Avatar
i only did it on one section of the hood and i stopped. yea i did every step correct i think i just used too much pressure and less lube.. i'll try it tomorrow and see what happens. thanks for the help!
Old Sep 20, 2006 | 09:56 PM
jordansg35's Avatar
i had the exact same problem. Apparently my hood wasn't fully lubed up. But what i did was polished it. Porter cable and an aggressive polish did the trick.
Old Sep 21, 2006 | 11:47 AM
Punchit's Avatar
Yea make sure your using enough lube and any chemical or cutting polish will remove the left over lube. You may need a medium to light cutting polish to remove any scratches though. Another tip that I don't think was mentioned was to clay in the shade and apply it to cool paint. If the paint is warm even slightly the lube is going to dry up much quicker. Hope this helps.
Old Sep 21, 2006 | 11:57 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Was the panel hot?
The clay gets softer with heat & marks easier.
Old Sep 21, 2006 | 01:19 PM
Espresso's Avatar
Why do you need to wipe off the lube if you're going to wash the car after claying anyways? Normally I wash the car, clay, and wash it again before drying. Is that not what everyone does?
Old Sep 24, 2006 | 04:10 AM
optimystic06's Avatar
I'm thinking it just clears the surface of the grime and stuff that you just lifted up (any that the clay didnt fully pick up)....giving you a clean slate to work on. you don't have to wash right after. I waxed mine today after I used a clay bar, I believe thats what most people do.
rezendvous420
May 31, 2020 01:26 PM
Sepsis
Feb 12, 2020 02:05 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
vstypicals
Jul 20, 2015 10:55 PM
