Cleaning Lake Country pads
Old Sep 28, 2006 | 09:40 AM
RalphieG's Avatar
Cloud someone tell how to clean these pad after using them? Is it safe to use a mild detergent or liguid soap?
Old Sep 28, 2006 | 09:43 AM
GTScott's Avatar
They make special cleaners for pads which work pretty well. I, myself, do not typically use them.
I have found that soaking the pads in a woolite or similar soap mix in a bucket and then drying them out on the rotary works well. For tougher things, I use a spray or two of APC and then soak them. This has not appeared to reduce the life of my pads to any noticeable degree.
-GT
Old Sep 28, 2006 | 10:42 AM
Punchit's Avatar
Snappy Clean Pad Cleaners work great for me. Just add the solution to water and let the pads sit for 15 minutes, rinse them out and let'em dry.
Greg @ Detailed Image
Old Sep 28, 2006 | 05:24 PM
G35stilez's Avatar
Concours d'Elegance
I put mine in the wash with my Microfiber Towels.
Hot Wash - little bit of detergent, cup of white vinegar, cup of white vinegar in downy ball, extra rinse
Old Sep 29, 2006 | 11:13 AM
aszatk01's Avatar
on autopia.org they recommended just washing out well with dishwashing soap. i did it just the other day and worked great. got EVERYTHING off and they look brand new.
Old Oct 1, 2006 | 09:45 AM
ksig113's Avatar
I wash mine with original Dawn Soap. Scrubbed it until most of of the cleaner came out, then left it in a bucket overnight with dawn again. Next day, it's just like I nevered used the pads.
Old Oct 1, 2006 | 01:46 PM
fortified's Avatar
If using conventional soaps for cleaning I think there is a possibility small soap traces may affect your polished surfaces. There are perfumes and other additives in detergents.
It seems it might be better to soak them (pads and MF towels) in a concentrated car wash detergent (the kind that does not strip wax) solution. Rinse them. Then put them in the washer with no detergent on the warm water cycle. Let air dry.
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
