Tire wet black damages paint?
Anybody ever hear of that before? I had some minor repair work done at a body shop this week and the owner mentioned to me that they found a lot of silicone on the surface of my fender and that they had to scrub it off before they could paint. According to the guy silicone reacts very badly with paint and can break down existing painted surfaces or prevent new surfaces from bonding with a new coat of paint.
I've used the guy before and his shop does top quality work. They didn't charge me anything extra for cleaning the silicone, so there's no motivation for them to make up the story. I'd just never heard of it myself before.
So if it is true, how do you wet black your tires without getting silicone particles on your paint? Supposedly airborne silicone can travel a long way in the air, so how can you keep it only on your tires? I've always used aerosol cans or pump spray containers in the past - would it be less of a problem with a wipe-on paste?
Thoughts?
Thoughts?
Silicone based dressings don't get absorbed into the rubber and have a tendancy to sling on to the paint. This silicone can harm the finish so I typically try and apply a thin amount of a water based dressing. Sometimes when I detail people's vehicles I can tell just by looking at the paint they use silicone based dressings. Its also not really good for the rubber like water based dressings that get absorbed into the rubber. Poorboy's World Bold n Bright works great for me and I would recommend to anyone looking for a safe tire dressing that still gives you a dark shine.
If you want to avoid getting the "tire shine" stuff on your paint, simply apply the tire shine (spray or liquid) to a pad or sponge (they make curved ones just for tire dressing) and use the pad/sponge to carefully rub the dressing onto the tires. This will prevent you from spraying your paint and your wheels.
http://www.infinitihelp.com/Ownershi.../ITB05-003.htm
INFINITI; INFORMATION ON PAINT STAINS CAUSED BY TIRE DRESSING
APPLIED VEHICLES: All 2000 and later Infiniti
SERVICE INFORMATION
An aftermarket chemical product called “tire dressing” is sometimes used on tires. When the tire dressing is applied, it may combine with an anti-ozonant compound (applied by tire manufacturers) to form a new compound that could stain vehicle paint. The paint stains occur if the wet tire dressing/anti-ozonant compound slings onto the vehicle paint when the vehicle is driven.
Paint damage stains caused by application of the tire dressing are NOT covered by Nissan warranty. Therefore, Nissan does not recommend the application of tire dressing to vehicle tires.
If a customer requests application of tire dressing to his/her vehicle, they should be informed that the vehicle
paint may be stained if the tire dressing is applied to the tires and that Nissan warranty does not cover the
repair of these stains. If the customer still requests the tire dressing be applied, consider the following:
SERVICE INFORMATION
- Water based tire dressing may reduce the amount of anti-ozonant that will be mixed/dissolved in the tire dressing compared with oil based dressings.
- A light coat of the tire dressing may reduce the amount of dressing that could enter the tires grooves/treads.
- To reduce the amount of dressing that could stain the paint: Use a dry towel to wipe off excess tire dressing from the tire, including grooves and treads. Then allow the dressing to dry completely.
Used to have the problem a lot where the tire dressing would sling onto the paint when driving. When I tried to wipe off the black specs off the paint they didn't come off readily. Solved the problem for me by ensuring the tire is throughly cleaned before applying dressing. After apply any tire dressing I usually wait a few hours for it to dry and adhere to the tire before driving. This seemed to solve my problem. BTW I currently use the Armour Arm High Shine on my tires. Works ok so far.
