Keeping Black cars clean
Old Dec 28, 2006 | 03:21 PM
toymachine2009's Avatar
i have so far had my infiniti g35 sedan black and its so hard to keep clean. I washed it really well when i first got it and used swirl free wax. It was really clean but if you looked at it in the right light like with the sun you can see some swirls not that bad of swirls but some areas and such
how do you suggest keeping the black car clean and what brand should i use for soaps and wax i just hate those swirls
what steps should i take
Old Dec 28, 2006 | 03:28 PM
dirtywally's Avatar
Black is such a tough color to keep clean. Nothing looks better than a clean, freshly waxed black car. Unfortunately, that "clean" look will only last about 15 minutes LOL. My old Eclipse was black and I loved how it looked all cleaned up, but I hated the maintenance on the paint (also Mitsu uses worse paint than what's on the G35, so it's extra hard to maintain).
I would recommend starting off by cleaning the car, wash with Dawn to remove wax, etc., claybar to remove any impurities, and coat that sucker with Zaino like crazy.
izmir41500's Avatar
G35driver Addict
Zaino is very popular. It doesn't remove them completely but it does hid them very well. If you like the wet look zaino is the way to go. you can go to zainobros.com to order and they also have detailing tips on there also. The process is follow is: Dawn soap wash, clay bar, Zaino soap wash, Z5 and Z2 in layers, usually about 3 each. I follow with meguire's NXT nanowax. it's amazing afterwards. I suggest using zaino and zaino quick detailer to keep it clean. Black is the hardest color to keep clean.
abcquackyxyz's Avatar
if you want to get rid of the swirls you need to polish the car using a cutting polish. Menzerna makes some great ones check properautocare.com for the info and also autopia.org has some great info on how to do it since it is a lot of explanation. Keeping your black g clean takes some elbow grease but once you get it polished and waxed nothing shines better.
Old Dec 28, 2006 | 04:19 PM
Picus's Avatar
Staff ALUMNI
https://g35driver.com/forums/repairing-detailing-diy/105461-detailing-caring-your-ride.html
Old Dec 28, 2006 | 04:29 PM
UFGatorG35's Avatar
Impossible. After having owned a black car and spending hours detailing it every weekend I am convinced all you need to do to end a drought is detail a black car and then go for a drive. It rained on me withing 30 minutes no matter what the weather report was.
Old Dec 28, 2006 | 04:30 PM
dirtywally's Avatar
If you go with Zaino, get the ZFX accelerator to go with the Z2 and Z5. It will literally save you hours of time when applying multiple coats.
Old Dec 28, 2006 | 04:56 PM
kenchan's Avatar
i have a black Legacywagon and on that car I use Griot's Best of Show
and use SprayOn wax. the light swirls are barely visible in direct sunlight.
Old Dec 28, 2006 | 05:22 PM
I really want to try the clay bar it seems like it will do good but after i wash the car do i have to dry it and if i dont dry it the car will spot will the clay bar take those spots out or should i just dry it?
Old Dec 28, 2006 | 05:26 PM
nightrider's Avatar
+1???
Old Dec 28, 2006 | 06:10 PM
TRUGRIDER's Avatar
have to dry it before you clay it
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
newg37
Jul 26, 2015 09:32 AM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
