touchup paint
touchup paint
will the touchup paint that is sold on infinitiwholesaleparts.com do well for chips on the bumper and stuff ? has anyone used it? thanks
2003.5 II G35 II Coupe II 6MT II BS II Prem. II
Re: touchup paint
i use the red all the time, its an exact match and works good if you use a very small amount. I have heard the white dosen't match right.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Re: touchup paint
lemme put it this way... it couldn't possibly look worse than a paint chip or nick! At around 5 bucks, what you got to lose?
Re: touchup paint
Yeah, i got the silver touch up from them, it took a little practice and some 3m rubbing compound "pepboys" which is like 3000 grit sand paper, it polishes the touch up, anda couple mistakes... it dries in seconds! but it most def. helps!!
Peace
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Nismo Oil/Radiator Caps | Solid Allum Pedals | Allum Matts (Infinit Logo) | 15% Tints | Valentine1 | Hide-Away License Plate!
Peace
-Eric
Re: touchup paint
There is a company that has a real good site for looking into paint and how to go about painting scratches or blemishes... I recommend checking it out. If you want to get paint from them as well they mix it directly using your VIN # for color verification. You can buy the primer, basecoat, and clear coat all from them... the also have the flex additive for paint that will be used on plastic or flexible parts such as bumpers or other flexible trim. Here is the website...
