Has anyone successfully touch-up Ivory Pearl?
Old Jan 18, 2007 | 03:18 PM
drtech's Avatar
Could you guys share your experience?
Thanks.
Old Jan 18, 2007 | 10:27 PM
NivlekGT's Avatar
After doing some research in the forums, I have attempted to touch up my IP coupe (paint chips on the front bumper) and wetsand it so it looks like new again. Unfortunately, I have not been able to get the paint to match perfectly like stock. I bought the Nissan OEM QX1 touch up paint (two bottles - 1 basecoat and 1 top coat) but I have been unsuccessful.
*Sigh* I was hoping to get the chips fixed myself before I got my clear bra installed!
Old Jan 19, 2007 | 03:07 AM
drtech's Avatar
After my research, I found that a few members got good results from paintscratch.com. It would be nice if they can share their experience.
Old Jan 19, 2007 | 11:16 AM
GR8TG35's Avatar
Ivory Pearl is really a hard color to match, either paint chips or painting a fender etc.
It is in theory a three part system.....your base coat (white) your pearl color, and then the clear coat.....
The touch up paint from Infiniti I have found to be too white....it always leaves the chip area slightly off color.....
I tried many combinations of using less base color and more pearl/clear, but I was only successful once or twice, and it was a real small chip.
I actually found the touch up paint from my I35 to be a closer match than the QX1.....but it seems now only the QX color code is available.....
Old Jan 19, 2007 | 01:37 PM
kenchan's Avatar
white pearl is probably the hardest color to match.
Old Jan 19, 2007 | 04:47 PM
drtech's Avatar
After touching up, if the color doesn't match. Can we redo it?
Old Jan 20, 2007 | 04:57 PM
kenchan's Avatar
usually you can use a polish (ScratchX, would work, but might need a
coarser one)and it will come off.
Old Jan 21, 2007 | 11:40 PM
abcdang's Avatar
i just bought touchup123's system to try on my IP, i'll post results when i am done
Old Feb 8, 2007 | 11:22 AM
G35_G35's Avatar
Is it necessary to apply clear coat for touching up IP?
Old Apr 6, 2010 | 09:15 PM
randyc's Avatar
Yes ,..the paint in the "pen" form from infiniti comes with 2 ends , one is white base coat and other is clear mixes with pearl !
Old Apr 9, 2010 | 06:45 PM
Blue Dream's Avatar
I drove ttrank's car solo
Wall Street Journal had an article on touch up kit results recently and the Dr Colorchip system was their highest rated product tested. I've heard good things about it on Driver and other forums. http://www.drcolorchip.com/
IP is a bitch to match no matter what.
Old Apr 10, 2010 | 05:21 PM
donut.'s Avatar
The color White is the hardest color to match. You'll never get it perfect. Goodluck.
MrIP35
Oct 25, 2015 11:13 PM
awalle01
Sep 28, 2015 12:36 AM
Jyounya
Sep 12, 2015 02:29 PM
