Wheel Repair for 19" OEM's?
Old Jan 21, 2007 | 09:53 PM
john5220's Avatar
While having my wheels rebalanced, the installer removed the old stick on weights on the inside of my polished 19" OEM wheels. It's in the area that's colored sort of a gun metal grey.
Has anyone encountered this problem, and if so, what did you do to repair them?
I'm thinking of rubbing shoe polish over the scratched areas, and removing the excess.
Any suggestions?
Old Jan 21, 2007 | 10:46 PM
kenchan's Avatar
that's behind the spokes? if so, just leave it alone. you can remove
the adhesive foam left-over, but your brake dust will accumulate over the
scratch in no time covering up minor imperfections.
Old Jan 21, 2007 | 11:11 PM
john5220's Avatar
It's actually not BEHIND the spokes, kinda BETWEEN them...so you can see them pretty easily!
Also, the goober didn't use anything like goo gone to remove the adhesive...just kinda picked at 'em...like with a screwdriver! Left some while gouge lines in the dark finish on the inner part of the wheel!
Old Jan 22, 2007 | 04:59 PM
kenchan's Avatar
yah, most shops will use a razor blade to remove those.
careless of them to scratch your wheel where it's visible though...
Xfactor
Dec 1, 2019 12:52 PM
hdmark
Apr 29, 2019 04:31 PM
EPG35
Aug 16, 2015 04:52 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
