little overspray
Old Jan 28, 2007 | 01:17 AM
rob40wilson03's Avatar
little overspray
just got my car back from the bodyshop from bein fixed and noticed a few minor places where there's just a little bit of overspray from painting it, sort of a chalkboard texture..... there is a little on the back windshield, a tiny bit on the trunk lid, a tiny bit on the "N" of infiniti and surrounding paint, a little on the tail light, and a little on the glass of the side mirror..... they are all small spots but im very picky
the body shop is 30 minutes away, what product can i use to remove this crap myself?
thanks
Old Jan 28, 2007 | 03:44 PM
GR8TG35's Avatar
You can try using a clay bar to see if it will take off the residual overspray, or if that doesn't work, try using a mild polishing compound......then follow up with a cleaner wax or just wax....
You can also try some mineral spirits, but that usually doesn't do a thing if the paint has had time to set up....
Good luck
Old Jan 28, 2007 | 03:55 PM
Nismo G's Avatar
Try a clay bar, iff its not to bad the bar should take it right off..
-sean
EDIT: did i just stttttuttter
Old Jan 28, 2007 | 05:55 PM
kenchan's Avatar
claybar for overspray.
Old Jan 28, 2007 | 06:06 PM
RBull's Avatar
Rated M
thanks
defintely try the clay bar especially soon after it has been painted.
Old Jan 30, 2007 | 09:32 AM
CERTAUTOG35's Avatar
No body has said this but chalkboard texture to me would mean Orange peel and that needs to be sanded and buffed obviously thats not the case on the letters but on the paint id venture to guess that
Old Jan 30, 2007 | 11:52 AM
redlude97's Avatar
Chalkboard texture is overspray, not orangepeel. Orangepeel still feels smooth to the touch, just has a slightly rough texture, just go feel you entire stock paint job, its covered in orange peel and isn't chalkboard in texture
Old Jan 30, 2007 | 05:30 PM
Actually my entire car is smooth and orange peel if bad enough is very trextured.... ive done plenty of work for body shops
Old Jan 30, 2007 | 05:38 PM
redlude97's Avatar
orange peel is on the order of mm in diameter while overspray is the order of micrometers in diameter, so its pretty easy to tell the difference between textures
Old Jan 30, 2007 | 07:35 PM
Just a little FYI overspray feels like sand paper
Old Jan 31, 2007 | 08:28 AM
exceldetail's Avatar
Clay Clay Clay................
digital sol
Jul 19, 2010 01:48 AM
pj-le
Archived Sales
Apr 22, 2008 07:56 PM
DocJohn
Jun 5, 2007 04:02 PM
Daniele
Mar 7, 2003 05:03 AM
