Does your hood feel rough?
Old Feb 2, 2007 | 01:41 AM
justice76's Avatar
I have clay bared and it just feels as if the hood is rough a little diffrent then the rest of the car.. It an 06 with 7k.. Anyone else notice this ?
Old Feb 2, 2007 | 02:28 AM
Calvin's Avatar
Overglorified Altima
i have an 06 with 11k miles on it. claybar always does the trick for me.
Old Feb 2, 2007 | 08:53 AM
kenchan's Avatar
hummmm.... 04 with 15k miles. same smooth feel as all the other
panels.
Old Feb 2, 2007 | 09:32 AM
LazerRed1's Avatar
If clay bar doesn't do it, you may need to polish. Start with the least abrasive on a small area. If that isn't enough, step up to the next abrasive. If that doesn't do it, go to a body shop and ask them about color sanding it. Don't try this at home unless you are a trained professional that is unless you are looking for an excuse to buy a CF hood.
Old Feb 2, 2007 | 09:42 AM
izmir41500's Avatar
G35driver Addict
do you have rock chips? a good clay baring takes most surface crap off, light dawn wash, then zaino should smooth it all out.
Old Feb 2, 2007 | 11:26 PM
justice76's Avatar
No rock ships at all just after a good wash you take a towel over the hood you can just hear a diffrence.
Old Feb 2, 2007 | 11:55 PM
twitch's Avatar
What type of clay are you using?
It's possible that you need a clay that’s more aggressive if you have some stubborn contaminants bonded to the finish.
Old Feb 3, 2007 | 02:09 AM
justice76's Avatar
I bought the kit from mothers found at most chain auto part places..
Old Feb 3, 2007 | 02:19 AM
gary c's Avatar
Rough Hood.........
To begin with DON'T use anything harsh on the surface of your hood!! You'll
do more damage than good. Try re-claying the hood and use plenty of
lube and more pressure.......then use a mild cleaner and finally good quality
wax........if this doesn't work take it to a detail shop and have them buff
out what ever needs to be cleaned off! LOL
Old Feb 3, 2007 | 02:29 AM
dvsmeth0dz's Avatar
i've got some pretty bad rock chips..does that mean i follow cars too close?
Old Feb 3, 2007 | 02:51 AM
anDross's Avatar
yes... yes it does lol
Old Feb 3, 2007 | 02:54 AM
dvsmeth0dz's Avatar
^^lol. now is there any way i can fix these rock chips?
Old Feb 3, 2007 | 03:17 AM
anDross's Avatar
I could be horribly wrong here.. but I'm thinking this is probably the way that you would go about with fixing some rock chips. However, I could be wrong. Please double check before you do anything of these next instructions on your car. I have not tried it myself.. this is just a shot in the dark. If the rock chips are too much.. just get the darn thing repainted
1) Touch up paint [depending on the size of the chips.. lots of people think toothpicks are a good size]
2) "Small" grit wet sand paper [very light grit.. the least abrassive I'm sure].. you use after the paint has dried. It evens out the paint you just put on over the chip w/ the rest of your paint.
3) Polish
4) Wax
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Blue Dream
Dec 5, 2015 10:56 AM
doakley92
Sep 25, 2015 12:58 PM
