Interior Neon's Wiring
Old Dec 5, 2003 | 06:50 PM
soG35's Avatar
how are you guys doing your wiring for your neons? I'm having a hard time sending a wire from the 12V on the passenger side to the driver side. Any one done this yet?
Old Dec 5, 2003 | 10:20 PM
ericinmia's Avatar
Re: Interior Neon's Wiring
I am doing this tomorrow... "blue neon mood lighting"
I am going to put the switch inside a custom mount in the ashtray!
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Dec 5, 2003 | 11:34 PM
Premier's Avatar
Hook it up to your door trigger instead of your domelight because it may draw too much power and burn your stock dome out. Find the door trigger wire and tap it in from there and run it parallel to the other side.
Pearl White 2003 Sedan & 2004 Coupe 6MT
Certified Window Tint & Detailing Specialist
Clearshield ("Clearbra") Authorized Dealer
Madico Authorized Dealer
www.machiii.net
Old Dec 6, 2003 | 01:55 AM
ericinmia's Avatar
i am going to get the current from the accesory line going to the 12v outlets... and then place the switch in a custom holder in the ash tray area (no g driver should smoke in their baby)
They would come on always with the car, and go off with the ignition, but the switch would allow me to turn them off when i wanted to... i got a pair of 12" mini blue neons for under the dash on both sides, and i am going to put their transformer on the driver side, a lot of room up under the dash, but got to be careful about steering, pedals, and other junk...
Peace
-Eric
Old Dec 7, 2003 | 10:59 PM
Chiphead's Avatar
Dudes,
Hide all your wiring! I went from the fusebox by the dead pedal and wired up 4 ultra thin cold cathodes and a pair of mood light on my center console! I also wiring it up to a sound flasher so I can have the light flash with music or be on solid. I bought all the cold cathods at Silicone Valley Computers on-line and paid less than $60.00 for white and blue lights all around. I used 6" mini tubes. They work great, light up the entire under section and are all hidden and out of the way. I tapped the fuse for the 12V cig light ont he passenger's side so if it blows, I don't loose anything. I can take some pics and post if you like! I have pics in my rides section with the fronts and I put a movie up on our movie server of the front lights flashing. I installed the rear under seat lights about a month after I did the fronts so the whole this was an exandable install! They're really the bomb!
'03.5 G35 Silver Sedan, AT
Stillen Intake, 350Z duct
Hyper-Ground Kit
Lowered!
Bulbs all around!
Splash Guards - Aero Pkg.
Under Dash and Console Custom Lighting!
Sub in the Trunk!
Old Dec 8, 2003 | 01:09 AM
SoCalTed's Avatar
I used LEDs instead of neons, but took power from the back of the driver's cig lighter. Pulled wires using a coat hanger that I pushed thru from the passenger side under the center console, attached wires, and then pulled it back...
check this out:
SoCalTed's LED moodlights
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
