Meguiars scratch X
Old Mar 8, 2007 | 12:58 PM
kraken316's Avatar
Meguiars scratch X
Hi everyone,
Just wondering if any of you have experience with Meguiars scratch X scratch/swirl remover. If so, how effective is it??? I have a very minor scuff I want to remove, you guys think it will work?
Thanks
Old Mar 8, 2007 | 01:24 PM
Cassman's Avatar
Originally Posted by kraken316
Hi everyone,
Thanks
Depending on the depth, it should. Just remember that you cannot just rub it on and wipe it off. You need to work it in. It contains dimishing abrasives, so work it over the scuff until it goes pretty clear. Then wipe off. It has worked well for me in the past.
Old Mar 8, 2007 | 01:28 PM
kraken316's Avatar
It's not deep at all.... not even thru the clearcoat. I wouldn't even call it a scratch.... just a scuff from friction....
Old Mar 8, 2007 | 02:07 PM
ttrank's Avatar
Grocery getter
You should be fine with the X.
Old Mar 8, 2007 | 02:15 PM
gary c's Avatar
Scratch X..........
Meguiars Scratch X is good for fine scratches or to remove the shadows on
your trunklid after you remove those i n f i n i t i letters.
Old Mar 8, 2007 | 02:17 PM
kraken316's Avatar
Thanks guys,
I'll pick one up tonight and try it out.... hope it works!
Old Mar 8, 2007 | 02:20 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
i used it on the first scratch i ever got (went through the clear coat) on the car and to this day i can only see it when i get down on the ground and look up. I've only re-applied it once in a year and a half and still looks good.
-GP-
Old Mar 8, 2007 | 04:11 PM
darnelled's Avatar
Discussed here recently
https://g35driver.com/forums/care-detailing/134696-scratch-x-question.html
Old Mar 8, 2007 | 04:22 PM
kenchan's Avatar
Its a nice tool to have.
As mentioned above, you need to work it in.
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
dcsbh1
Oct 1, 2015 03:15 PM
vQFamily
Sep 30, 2015 01:17 PM
cmesidewayz
Sep 29, 2015 09:28 PM
