Zaino and wax question...
Old Jun 4, 2007 | 01:59 AM
befree112's Avatar
Not sure if this has been asked before or if this is common knowledge... but if I use Zaino Z2 and Z5 as the base coats, can I add another coat of... say... tutle wax?
And when the wax wears off, will the Zaino wear off with the wax? Or will it still be remain on the clearcoat?
Thanks for any clarification.
Old Jun 4, 2007 | 02:05 AM
ttrank's Avatar
Grocery getter
I'm sure you can but the results may not be as good as if you kept using Zaino.
Old Jun 4, 2007 | 11:32 AM
SLVR JDM's Avatar
I think you'd probably want to continue applying additional coats of Zaino, since it has the ability to be layered. I wouldn't think it would melt off if you topped it with something else though.
Old Jun 4, 2007 | 11:42 AM
Garnet Canuck's Avatar
Traveling Administrator
Yes, you can add a layer of wax over a sealant. Alot of people do this because you get the durability of a sealant, and also the deep wet look of a Carnuba wax. It's recommended that you let your sealant cure for 24 hours before you apply any wax over it. I personally use Zaino Z2/Z5 with a coat of Natty Blue's Paste wax over top.
Also, when the wax wears off, the Zaino will still be there of course.
Old Jun 5, 2007 | 01:22 AM
befree112's Avatar
Thanks for all the answers!!
One more, If i use ZFX additive, that means that it will cure immediately, right? Or do I still wait 24 hours?
Old Jun 6, 2007 | 02:10 AM
tod071's Avatar
Yes and Yes. Normally, you'd wait 24hrs for the sealant to cure. But with ZFX, you can layer immediately after wiping off.
My question is, what are you trying to accomplish? If durability and longevity are issues, I'd agree with hoenignd and ttrank, keep layering with Zaino. If you are looking for depth and gloss, Garnet Canuck's way is right on with the Natty's. I prefer Chemical Guys Pete's 53 or 5050 over Natty's, but Nattys is cheaper.
I think all would agree, you just have to try it yourself and see which you prefer. Zaino + Zaino or Zaino + Nuba???
Old Jun 7, 2007 | 03:04 AM
befree112's Avatar
Thanks, I'm looking at longevity as well as depth and gloss from wax. I wanted to make sure that the 3 layers of Z2/Z5/Z2 that I spent so much time on will not be compromised in longevity if I apply wax is all.
Again, thanks!
Old Jun 7, 2007 | 03:21 PM
Goonz SVT's Avatar
I dont think you should use anything else once you have used zaino. Since I have zaino'd mine since the day i drove it home. It will never see any other type of wax if its not Zaino. I believe a while back I spoke to a zaino representative and he said that its realy not a good idea to switch and use something else once you have used zaino...:shrug:
Old Jun 7, 2007 | 11:04 PM
tod071's Avatar
Zaino is not a wax. Its a polymer sealant. It may be made differently than others, but its still a sealant. You can apply a carnauba wax to add depth and gloss over any sealant.
I spoke to an Infiniti salesman and he said it wasn't a good idea to switch to any other car besides Infiniti, not even a Nissan.
Old Jun 8, 2007 | 08:51 AM
+1. You can apply a Carnuba over any sealant, including Zaino. You just can't apply a sealant over a Carnuba because sealants don't bond well to Carnuba waxes.
If any of you guys want to read a great write up, click here.
Old Jun 13, 2007 | 12:42 AM
pullover20's Avatar
FGC general member
how much does Zaino usually run and is it just one type of sealent or are there lots of different products?
which gives the best wettest look
and would it be a good idea to used a mothers carnuba wax over a sealent?
im new to all this sorry
Tmatheso
Dec 13, 2015 03:24 PM
TNRocker
Sep 21, 2015 08:36 AM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 11:25 PM
bigmike
Sep 17, 2015 01:58 PM
