How to remove permanent marker on exterior?
Old Jun 11, 2007 | 01:29 PM
dunglan7's Avatar
Does anyone know how to remove a permanent marker stain on exterior? I purchased a spoiler online and they wrote "G35" on it with a permanent marker. I tried waxing it off but it's still there. Seems like the wax sealed the writing.
Old Jun 11, 2007 | 02:40 PM
Detailed Image's Avatar
A light abrasive polish such as Meguiar's ScratchX should take it off with ease and can be hand applied and found locally at almost any automotive parts store.
Be sure to follow up with a sealant or a wax to ensure your spoiler is properly protected from the elements.
George
Old Jun 11, 2007 | 02:55 PM
03silver's Avatar
rubbing alcohol will work too
Old Jun 11, 2007 | 03:03 PM
g4dc's Avatar
Thumbs up
use a white board marker over it and it takes off perm. Pen and marker
Old Jun 12, 2007 | 04:58 PM
kenchan's Avatar
i think the marker stained into the clear... so scratch-x would be the
choice for me too.
Old Jun 12, 2007 | 05:08 PM
izmir41500's Avatar
G35driver Addict
so the spoiler is painted? and they wrote g35 with permanent marker on it? that sounds retarded.
Old Jun 12, 2007 | 06:03 PM
dunglan7's Avatar
^ Yeah I guess they couldn't keep track of what type of spoiler it was. Or they were too lazy to attach a tag on it.
Old Jun 12, 2007 | 09:35 PM
toymachine2009's Avatar
have you tried what he said that really works. Wont harm the paint at all. Just write over the mark with the white board marker and erase it and see if its gone
Old Jun 12, 2007 | 10:21 PM
DHCrocks's Avatar
lighter fluid, the kind for zippo. just be sure to wax after, cause it'll remove it too.
Old Jun 12, 2007 | 10:47 PM
ScubaSteve312's Avatar
maybe apply Oops! or Goof-Off
recommend applying it to an inconspicuous area first just to make sure it doesn't ruin the paint
Old Jun 16, 2007 | 01:27 PM
ke104's Avatar
be very careful with goof off, it will soften certain paints/clearcoats.
Old Jun 21, 2007 | 03:28 PM
Pska's Avatar
goof off will totally destroy your paint. I bet a claybar would take the marks off
Old Jun 21, 2007 | 04:25 PM
dunglan7's Avatar
I tried the marker and it didn't work. Will try Scratch X next.
Old Jun 30, 2007 | 12:14 AM
srsly's Avatar
what about a light wet sand?
Old Jun 30, 2007 | 12:27 AM
While this method would work in removing the market, but there's no reason to remove that much excess clear coat for a surface stain. It should come off pretty effortlessly with something much less aggressive than wet sanding. Ideally, you want to remove as little clear coat as possible to remove the markings.
George
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
R350k5
Lights
Jan 12, 2016 09:22 AM
dcsbh1
Oct 1, 2015 03:15 PM
