Porter cable vs other random orbitals
Old Aug 14, 2007 | 10:03 AM
darnelled's Avatar
Go with a PC. I had a budget one a few years that I will give you for free if you really want it. It has little power and no good pads to get swirl removal done well.
Bought my PC here-
http://www.autodetailingsolutions.co...20Specials.htm
Old Aug 14, 2007 | 07:39 PM
RJsd7's Avatar
Bought my PC here-
That G100 was actually exactly what I was looking at for that special price. But is the LifeTime warranty really worth it?
I actually found the PC for less than 100 here
http://www.coastaltool.com/cgi-bin/S...htm?E+coastest
should I get that then get the pad kit from
http://www.detailuniversity.com ?
Thanks so far guys! I love this forum
Old Aug 16, 2007 | 10:30 AM
darnelled's Avatar
It's a good price, but then you have to add in the backing plate and pads.
The need for a warranty is up to you. I think PC has a good reliability history, but you never know with anything electronic. I bought a used PC saw that has never had a problem despite being abused by its former owner- very well built.
Old Aug 16, 2007 | 10:34 AM
MidnightG35X's Avatar
I'd throw in my vote for the UDM
Old Aug 16, 2007 | 12:18 PM
redlude97's Avatar
Do you have one? I'm thinking about upgrading. How do you like it?
Old Aug 17, 2007 | 05:01 PM
Yes, I do have one. I like it better than a PC. I never owned a PC, but used somebody else's. The UDM will still slightly bog down at low speeds with moderate/high pressure, but barely at all at high speeds. I'm still trying to decide which compound/polish I like best for it. So far its between Menzerna Intensive Polish and Optimum Compound. IP breaks down quicker, but OC seems like it does a slightly better job. I use the DAS pads that came out along with the UDM also. I felt a random orbital was necessary with a black G. After polishing it passes the 5 foot test, but not so much the bring a light right down on the paint. Oh well, such is the life of a daily driver!
Old Aug 17, 2007 | 10:36 PM
MikeyC's Avatar
Do you stop after the Intesive Polish or Optimum Compound? What you could be seeing is polishing haze. Especially on a black car, I would finish up with a finishing polish like Menzerna PO106FF or Optimum Polish.
Old Aug 18, 2007 | 03:09 AM
There is definitely haze afterwards with the OC, not as much with the IP. I follow up my compounds with ZPC on a blue (finishing) pad.
Old Aug 19, 2007 | 05:45 AM
tod071's Avatar
The UDM has more power and torque. A little less vibration, but limited to a 5" counterweight, meaning the largest pad you can use would be a 6-6 1/2". They are supposed to release the 6" counterweight and replace existing customers' UDMs at no charge.
I also have a Festool RO150FEQ, dual mode RO/forced rotation polisher and love it. Much more power and rotary-like mode for even more correction ability. Pricey, but IMO well worth the price.
Old Aug 19, 2007 | 09:39 PM
RJsd7's Avatar
ended up buying this one
http://www.autodetailingsolutions.co...20Specials.htm[/QUOTE]
with some blue pads to finish it up fomr DU
06g35
Feb 14, 2022 05:59 AM
KallDay86
Jan 8, 2016 12:42 AM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
JustinMKN1
Sep 18, 2015 03:40 PM
