How To Properly Apply Touch Up Paint
Old Oct 24, 2007 | 03:53 PM
hullio's Avatar
Title says it all. I remember using some touch up paint on one of our old cars and it didn't turn out so well. I'm going to buy some Blue Onyx touch up paint for the G and touch up little scratches here and there but I wanted to know how to properly apply it so it won't leave an obvious mark.
Old Oct 24, 2007 | 04:04 PM
fais's Avatar
In order to do it properly, I think after you apply the touch up paint and let it cure, you have to do some spot sanding to level the paint down and then follow with polishing preferably with a buffer. I remember reading a how-to by Kevin that was pretty detailed, I think it might be on his website: http://www.gtaindetail.com
Old Oct 24, 2007 | 06:08 PM
Carbnjunkie's Avatar
good link!
Old Oct 24, 2007 | 07:20 PM
Scrooge's Avatar
I think he had it on autopia ???
Old Oct 24, 2007 | 09:53 PM
fais's Avatar
Just checked, on Kevin's site he mentions a little bit about it in the FAQ section but there's probably a more detailed how-to on it on autopia.
Hullio I'll probably be doing some touch up and sanding on my car in a few weeks time since I got some stone chips to take care of, if all goes well I can probably help ya if you haven't taken care of it already by then. I have a porter cable and there's a power outlet in the underground parking of my condo in Sauga so it's pretty decent environment to work in, I do my polishing down there usually.
Old Oct 25, 2007 | 12:10 AM
Glycerine's Avatar
Kevin's Thread: https://g35driver.com/forums/care-detailing/95437-how-chip-repair-wetsanding-some-obligatory-polishing.html
Pay attn to the autopia.org links he has in there too.
Words of advice: Use an EXTREMELY light touch when sanding. I was just holding it using the weight of the block and managed to sand nice little troughs where the edges of my block (a 2x1 eraser) were.
Also, lightly sand the edges of the chip or scratch so there's not a hard edge. They do make sanding pens for that.
Use a tooth pick to apply in chips. And once it flows off the toothpick, LEAVE IT ALONE. I had it curl on me and level some nasty dark spots.
I was worried about dying times with low temps and rain coming, and used some halogens to speed the process along. Seemed to work.
Old Oct 25, 2007 | 10:52 AM
fais's Avatar
Thanks for the info
Old Oct 25, 2007 | 04:30 PM
hullio's Avatar
Thanks everyone for the info.!
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
alessandro
Oct 8, 2015 09:29 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
cmesidewayz
Sep 29, 2015 09:28 PM
