rear tint has lifting..dealer said no fix possible
Old Feb 23, 2004 | 08:41 PM
pingo's Avatar
My dealer installed rear tint has what appears to lifting in certain places at the top of the window. The installer at the dealer said its because of the "Matrix" which he said is where the window has the darker color with white dots in it at the top...said it can't be fixed. Any opinions? Pingo
Old Feb 23, 2004 | 09:06 PM
SFLG35's Avatar
FGC President
Re: rear tint has lifting..dealer said no fix possible
dont think so
dot matrixes are hard to tint over and the tint doesnt seem to stick to them very well
some installer dont even tint over them and just cut the tint at the start of it
hope that helps
Daniel
5AT Coupe / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights
Old Feb 23, 2004 | 09:23 PM
ABQ_G35's Avatar
I have a sedan, but I have some spots on my rear window tint, that only show up under certain light, I took it back to the tint place, and the guy couldn't see anything, and neither could I at that time, I keep going to run it back once more, but everytime I clean the window, I think, geez, this is really hard to get to, maybe it's extremely hard to tint then as well, I may just live with it, we'll see!
Brilliant Silver/Graphite/Chrome Wheels '04 Sedan/5AT
Old Feb 23, 2004 | 10:53 PM
pingo's Avatar
oops..should've said whiter coloring with dark dots...Pingo
Old Feb 23, 2004 | 10:57 PM
Premier's Avatar
The dot matrix will push the tint up, but you can wait about a week after the tint job, and go back to the shop to have them push it down. It will reduce the silvering along the dot-matrix.
Pearl White 2003 Sedan & 2004 Coupe 6MT
Certified Window Tint & Detailing Specialist
Clearshield ("Clearbra") Authorized Dealer
Madico Authorized Dealer
syu@machiii.net
Old Feb 23, 2004 | 11:53 PM
nate's Avatar
I plan to have mine done at autotrim design and they said they now use a spray coating instead of film in those areas when needed, and then tint as usual next to it. Although they said the minimal bits on my sedan shouldn't be a problem anyhow.
http://www.autotrimdesign.com/main.html
2003.5 Sedan Black/Black w/ sport, premium, aero, and winter packages. See my profile for updated mods list and pics.
Old Mar 15, 2004 | 01:54 PM
Gyromight's Avatar
A good installer will know how to lay tint down on the black dotted areas. Mine came out fine. I used a company called Wintech. Their website is wintechtinting.com. They do a very professional job and work a lot of dealership cars. Ceramic tint rocks!
2004 G35 Coupe Prem / Aero D. Plat/D. Graph
Old Mar 15, 2004 | 02:14 PM
almeida79's Avatar
Before your installer applied the tint he should of scrubed the area with a 3m scotch pad.
Old Mar 19, 2004 | 05:03 PM
MisterG35Tee's Avatar
how much did you get your ceramic tint job for? how is the tint holding up? can you notice a significant heat difference?
04' G35C 6MT TwilightBlue/Willow/Prem/Nav/SG
Old Mar 22, 2004 | 11:38 AM
Gyromight's Avatar
The ceramic tint is very nice but not quite as dark as I wanted it. I was looking for something limo-like. I got the Ceramic 30 all the way around. In any case, it blocks heat insanely good. When they come out for the install, make sure they bring the test box. The test box has a heat lamp which demos the ceramic tint vs conventional tint. On one side with the conventional, I could feel the heat pretty strongly coming through the box. He rotated it to ceramic and I didn't feel a thing. It's simply amazing that ceramic tint!
Old Mar 25, 2004 | 09:17 AM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Pingo, Go back to the Installer and have He/She trim the tint off the Matrix (dots) and ask them to add a Mat or thin liner to the Matrix area. I'm not sure what the matting is called , but it worked GREAT for my G.
Old Mar 25, 2004 | 01:06 PM
G6MT's Avatar
G'z 6MT
Here's a pic
Old Mar 31, 2004 | 03:44 PM
CBEtravel's Avatar
I am guessing that 6mt is talking about black vinyl window film....
I used black vinyl for the dot matrix area of the window on my last car and it looked great. Zero lifting. Which on a black car can really **** you off.
There are black vinyl window films that are used for 100% blackout... they are the same thickness as regular tint films and have an adhesive on one side.
You can use the vinyl for the dot matrix area and whatever tint film you want for the rest of the window. A good tinter can then cut a matching line in the tint film so you dont see a gap.
Not all shops offer this, so call around.
However, a good tint shop shouldn't have a problem w/ dot matrix windows regardless...
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
beevanhuynh
Jul 23, 2015 01:37 AM
emorehs
Jul 17, 2015 09:45 AM
newbdriver01
Jul 15, 2015 06:10 PM
