Best Way to Clean Headliner?
Old Nov 23, 2007 | 09:07 PM
bmpnride's Avatar
I drive with my windows down alot and over the past 4 years, I have collected some dirty areas on my headliner. What is the best way to clean it up? I cant get it off with a vaccuum as it it imbedded within the material. I dont want to take it into a shop just to have them do something I can most likely do for free. Any help will be appreciated.
Thanks
Old Nov 23, 2007 | 11:48 PM
Scrooge's Avatar
Try a 6:1 diluted Woolite. Spray to the head liner and and agitate with a terry cloth damp in warm water. Work for me when I got tire mark on my head liner.
Old Nov 26, 2007 | 01:09 PM
Detailed Image's Avatar
I'll usually spray a fabric cleaner, like 303 Cleaner & Spot Remover, on to a microfiber towel and blot around the area. Try to avoid scrubbing the headliner outside of the area of the stain, as you can often expand the stain larger than what it is. Woolite or Folex are good options you can typically pick up locally.
George
Old Nov 26, 2007 | 01:20 PM
The_Scooch's Avatar
Get it wet with a soapy solution of Woolite(mix per instructions) and spray it on with a spray bottle, work it in with soft brush or rag and vaccuum out the solution. Wet again with plain water and vaccuum that out.
I've not had to do my G but my daughter sprayed Pepsi all over her headliner (Mustang) and that is how I cleaned it up. I had to do the whole thing because it cleaned it so well, I didn't want it looking uneven.
Old Nov 28, 2007 | 12:14 PM
patrickwong's Avatar
woolite won't stain the headliner?
Old Nov 28, 2007 | 06:20 PM
Jeff92se's Avatar
Red Card Crew
No. I've used this method with great results. I also have Folex and use it on my home carpet but haven't tried it on the headliner. I imagine if our local detailing expert says it's okay, then I trust that info.
Old Nov 28, 2007 | 06:58 PM
RBull's Avatar
Rated M
George
Both of these would work great. My company provides interior maintenance, repair and cleaning services for auto dealers' used cars and we use a chemical dry cleaner. Most headliners are very tough and you shouldn't have too much trouble removing a little dirt and minor staining.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
