Seat Belt Cleaning Tips?
Old Dec 30, 2007 | 05:42 PM
jlin615's Avatar
My stone interior seat belts got pretty dirty from the previous owner. You guys got any tips of cleaning it? I was thinking about just wiping it down with water and cloth.
Old Dec 31, 2007 | 02:04 PM
Scrooge's Avatar
Tried use Woolite(Laundry soap)1:6 on the belt with a damp hot terry cloth towel and hold it there to soak up any of the dirt.
Old Dec 31, 2007 | 06:34 PM
TOGWT's Avatar
Seat Belts:
Maintenance clean seat belts with a 5:1 Woolite® distilled water solution.
For spot stains use a fabric cleaner (303 Cleaner & Spot Remover™)
Cleaning-
1. Pull the belts from the retractor and gently close the door on the belt, clean and allow to air dry before opening the door and retracting the belt. Do not use bleach or strong detergents, or dye on the seat belts as this may severely weaken them and render them ineffective in a crash.
2. Once fabric is dry apply a fabric protection (303TM High Tech Fabric Guard)
3. While you are cleaning the belts, take the opportunity to closely inspect them for damage and security of attachment, ensure here are no cuts, tears or abrasions (you should always inspect for damage etc if they get caught by a closing door)
After a while the seat belt mechanism becomes slow and / or will not retract when released. This can be avoided by cleaning the upper anchor; as the seatbelt retracts it leaves behind a film of dirt, which builds up over time. But by taking a Q- tip and some Isopropyl alcohol (IPA) you can clean the seat belt anchor / retracting mechanism. Once clean add some Plexus Plastic Cleaner to provide lubrication.
Alternative products - C-28 Seat Belt Cleaner and Spot Remover from PRO® to make detailers jobs a lot easier Seat Belt Cleaner and Spot Remover is a non-flammable and non hazardous concentrated cleaner that safely removes dirt, oil, grease and stains from seat belts - http://www.professionalcarcare.com
cmesidewayz
Sep 29, 2015 09:28 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
Kicknshift
Sep 3, 2015 09:35 AM
pasjr1972
Sep 1, 2015 10:17 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
