Cleaning Exhaust
Old Mar 1, 2008 | 02:14 PM
SteveBlake's Avatar
Cleaning Exhaust
I bought a used HKS exhaust and i wanted to know what i can use to clean it to get it back to being nice and shiny. It has some wierd spray looking stuff on it.
Old Mar 1, 2008 | 02:35 PM
Bimmer G's Avatar
Hey man i bought my HKS Ti used too. I used master klean aka a heavy degreaser, and then i used A clean rag and polished it.
Attached Thumbnails Cleaning Exhaust-g35-hks-exhaust.jpg   Cleaning Exhaust-g35-burnout-college-park.jpg
Old Mar 1, 2008 | 02:59 PM
SteveBlake's Avatar
Thanks for the info
Old Mar 1, 2008 | 03:29 PM
SidewayzSupra's Avatar
I would do the Heavy degreaser and then rub Eagle One Nevr dull on and whip off after a few minutes repeat that about 4 times. It will make a huge difference
Old Mar 1, 2008 | 04:24 PM
SteveBlake's Avatar
i just used a degreaser on it and it definitely did not get the sprayed on stuff off
Old Mar 1, 2008 | 04:58 PM
never gone's Avatar
Try 0000 steel wool and some Flitz metal polish. If that doesn't work....good luck.
Old Mar 1, 2008 | 09:54 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Wenol FTW
Wenol (Red Tube) is excellent for deep cleaning and restoration projects. This cutting polish can be used on any metal to remove tough stains, oxidation, acid rain spots, and surface rust.
Old Mar 1, 2008 | 09:58 PM
06g35meister's Avatar
Old Mar 2, 2008 | 12:03 AM
Joaquin03's Avatar
Staff ALUMNI
yea.. i would use some metal polish.. there's plenty of choices out there, like what meister just posted
Old Mar 2, 2008 | 12:04 AM
Scrooge's Avatar
+1 for steel wool and metal polish. After you get done with the steel wool, use a foam to bring it to a higher shine.
Old Mar 2, 2008 | 04:39 AM
never gone's Avatar
it looks like overspray of some kind.
Old Mar 2, 2008 | 05:11 PM
SteveBlake's Avatar
What are some stores i can buy these polishes from?
Old Mar 2, 2008 | 06:48 PM
Scrooge's Avatar
Autozone, Checkers, Kragen, Pepboys, Schucks, Walmart, Target, Kmart, and any Auto paint supplie shop.
Old Mar 2, 2008 | 06:50 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Try metal polish, also if you take the exhaust off the car it will be 100X easier to clean.
Old Mar 3, 2008 | 02:50 PM
Jeff92se's Avatar
Red Card Crew
Looks like overspray. Not sure if those metal polishes are strong enough. Might want to try laquer thinner and see if that takes it off. Could try 0000 grit steel wool but I'd try a real small spot to make sure it doesn't scratch
