GREAT tool for winter washers!!!
Old Mar 3, 2008 | 09:03 AM
GreenGoblin's Avatar
The goblin resurrection
ya ob is a paint but looks so good when it is clean
Old Mar 3, 2008 | 11:46 AM
citymunky's Avatar
Which is like 2 min's. LOL
Old Mar 3, 2008 | 11:55 AM
MixturePinoy's Avatar
nice.. i'm going to look for this today
Old Mar 3, 2008 | 12:24 PM
DRA-G35-ON's Avatar
I'm gonna go buy the goo gone "gun" and try it out. thanks for the info
Old Mar 3, 2008 | 01:36 PM
jl114's Avatar
Originally Posted by Adon
massive bukkake shot!
Was I the only one that laughed?
Old Mar 3, 2008 | 02:39 PM
Scrooge's Avatar
I still think this one better
Cause you get this much foam with this one
Old Mar 3, 2008 | 02:43 PM
Jeff92se's Avatar
Red Card Crew
So when you guys use this, do you need to soap up the wash mitt? Or do you rinse that all off and wash as normal?
Old Mar 3, 2008 | 02:46 PM
hm. great question jeff.. my car is pretty dirty.. i don't know if the water pressure could cut through the grime
Old Mar 3, 2008 | 07:17 PM
never gone's Avatar
Yes guys, you still use a wash mitt. You soak the car first to loosen all the crap up. Then you do the usual soap and bucket (2 bucket preferred), and wash like you normally would. The pre-soak just helps loosen the dirt off to help prevent swirling of the paint.
The faom gun above will give you a little more foam but a misconception is that lots of foam means it's better, not true. Lubricity is the name of the game and that can be done with foam or without. Look at Optimum No Rinse. There is no foam at all, not even a bubble and that stuff works amazingly well. Also, the foam gun pictured above will run you, at MINIMUM, $60.00 where as what I use will cost you $7.99. So yes, the foam gun gives you more foam, but foam isn't what's important, lubricity is. However if foam was the main objective, I don't know if I think the foam gun gives you $52 worth of more foam.
Old Mar 3, 2008 | 07:27 PM
Jeff92se's Avatar
Red Card Crew
My question is when you spray the sudsy soap on, do you leave it on and start washing as normal? Or do you spray the stuff on, soak, rinse it off and THEN wash as normal?
$8 is cleap but don't you have to use up the stuff inside first?
Wouldn't this work also?
Old Mar 3, 2008 | 07:36 PM
Jeff92se's Avatar
Red Card Crew
Or this. It's the same price at $8 so I dunno: Fully adjustable though.
Amazon Amazon
Old Mar 3, 2008 | 09:40 PM
Scrooge's Avatar
Heres three foam guns I saw at home depot in the $1-$15 range
$9
$15
5$
Old Mar 3, 2008 | 09:55 PM
Scrooge's Avatar
Also I thought with more foam that the foam gun makes that the foam encapsulate more dirt and also stays cling to surface help loosen dirt and lubricate the paint longer. Also I thought lubrication can be determine by the soap your using.
Old Mar 3, 2008 | 10:23 PM
never gone's Avatar
Pretty true to some extent. I don't know if I buy the fact that the foam will really encapsulate the dirt so to speak. The kind of dirt that would just fall into a soap bubble will surely also come right off when rinsing the car. For stuff that's really gunked on the car, heavy foam is mostly air bubbles and can lack the real wetness needed to start breaking the grime down. Either way, both are going to work and accomplish what we want it to. If someone wants to spend $60 on a foam gun, go for it. For me personally, I can't justify the cost if I have something that will basically do the same thing.
Old Mar 3, 2008 | 10:33 PM
  #30
never gone's Avatar
You don't have to rinse the car first. Soak the car in soap, let it sit for 3 or 4 minutes and then take your mitt out of the bucket and wash as normal. As for using the stuff inside first, you don't have to use the exact thing I did. I'm assuming some of the other guns posted would do a similar job. I just happened to have an almost empty bottle of the stuff and the thought came to me to try it. I just dumped out what little fluid was left, cleaned it out and went to town.
