so i was looking around...
Old Mar 4, 2008 | 07:57 PM
infinitcash's Avatar
and i open the oil cap and notice my engine is pretty dirty... what would be some good things to do to clean it up? in terms of additives? and where is the oil filter at?
Old Mar 4, 2008 | 09:37 PM
lexusk8's Avatar
I would probably just get a used cloth and wipe down the dirt and gunk residing around the oil filler hole. I wouldn't worry about putting in additives and such into the engine. The G35 engines are pretty strong as long as you maintain the oil changes.
As in most other cars these days, the oil filter is located at the bottom of the front end. There is a large plastic splash guard held on by at least a dozen 10mm bolts you'll have to remove to access the oil filter.
Old Mar 4, 2008 | 10:53 PM
good lookin out thanks for the help, i looked in the owners manual and saw it, but it didnt tell me the bolt size... it wasnt that dirty it just had little bits of crap and was glazed oil color yellow.
Old Mar 5, 2008 | 02:18 PM
Scrooge's Avatar
You can try seafoam. Suppose to clean the carbon inside your cylinder and also all the gunk inside your engine.
Old Mar 5, 2008 | 09:07 PM
ive used seafoam on my camry, and im not too confident it did anything. but opening the oil cap i dont think i should see nasty **** inside the engine.
GreenG35Sedan
Jun 8, 2016 08:08 AM
lil_will
Texas
623
Feb 27, 2013 07:15 AM
rimlas
Archived Sales
Feb 28, 2010 08:36 PM
