Is it necessary to polish after claybar
Old Apr 8, 2008 | 02:13 PM
Bad Influence's Avatar
As the title says....or can I just use a sealant then wax.
If yer, what are the benfits of polishing after cb.
Thanks.
Old Apr 8, 2008 | 02:19 PM
Jeff92se's Avatar
Red Card Crew
The benefits would be the same as if you polished at any time. Clarbars remove contaminents. It's not really a polisher. So if you have scratches or marring before claybaring, it will be there after.
Old Apr 8, 2008 | 02:24 PM
TheIvoryG's Avatar
Like Jeff said...they are two very different processes.
If you are looking to get rid of contaminants(overspray, etc) then claybar is your choice. But if you have marring, swirls, etc, then polishing is the only option you have.
Old Apr 8, 2008 | 02:28 PM
Dakkerz's Avatar
Do you have to polish immediately after clay barring, or is it ok to clay bar and then polish the next day? Or will there be a risk of contaminants collecting on the car in that short amount of time?
Old Apr 8, 2008 | 02:44 PM
redlude97's Avatar
you'll be fine, but you should reclean the car before polishing. A wipedown with a QD if the car wasn't driven should be adequate
Old Apr 8, 2008 | 04:02 PM
Dakkerz's Avatar
Cool thanks for the info Redlude. I'm planning on doing a full detail this Sat but it would definitely help me on my limited time budget to get the claying done the night before.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Detailed Image
Sep 11, 2015 08:37 AM
