Hazy Headlamps
Old Apr 23, 2008 | 02:33 PM
Da-G-SpoT's Avatar
Even if you covered/protected the light with a clear bra just from a cleaning, wouldnt it come back out? Since its the lights plastic the one affected... Unless you mean to have it prof. cleaned and THEN apply the clear bra? I think that this way it would be GREAT.
Old Apr 23, 2008 | 04:09 PM
ClearBra_Guy's Avatar
I am talking about getting them back to clear first. Once you put the film on it seals the light from the outside elements. They will stay clean and clear.
Old Apr 23, 2008 | 11:01 PM
Beebo's Avatar
the haze will always return because now you've stripped the UV protection from the plastic, you will now have to maintain the lights every month or so, wetsanding and wax are not going to fix the problem
very true...
Originally Posted by ClearBra_Guy
If you cover the light with clear bra film after cleaning them you will never have to touch them again.
true... good idea
Old Apr 24, 2008 | 05:46 PM
chairman25's Avatar
Here is an article that I found. I hope that it helps
Yes, I also have an Audi S4.
http://www.audiworld.com/tech/ext.html
Old Apr 24, 2008 | 08:42 PM
ckg35's Avatar
Originally Posted by reverse
I will try the toothpaste....is colgate ok? lol
Just don't use a gel (clear) toothpaste. I don't think it's abrasive enough to do anything. Any white paste should work, or one of those polishing (not bleaching) pastes might even work a bit better.
Old Apr 25, 2008 | 12:35 AM
GBlitz's Avatar
Originally Posted by Da-G-SpoT
Well my boy in Miami started this little headlamp claning business not too long ago.
That's perfect!! Please PM me with his info and maybe I'll do the clear bra thing. Still, if they don't come out right maybe I'll just upgrade to a set of projector headlamps.
jsimonk
Dec 22, 2023 03:49 PM
twentyeggs
Sep 11, 2015 03:58 PM
JKL1031
Lights
Sep 9, 2015 01:27 AM
Danielek
Aug 11, 2015 09:33 AM
newg37
Jul 26, 2015 09:32 AM
