Collinite 476s deodorant stick ???
Old May 6, 2008 | 10:25 PM
Scrooge's Avatar
Just kidding.
Ok for real. I got this idea from Eliot Ness over at autopia (Thanks). I thought it was a great way he thought about using the idea of applying wax to a applicator or machine pad like how you apply the deodorant to your underarm.
http://www.autopia.org/forum/detaili...stick-wax.html
So first I had to get a wax to try out with. This is where I got out my Collinite 476s. Then I had to get a used Deodorant stick container to pour in my wax. This is where I got my use old spice container.
So I had to clean it out with some APC and Dawn Direct foam
After it was clean. It was time to melt the wax. I left the wax in the original tin can and put it on the stovetop. Lite to a low flame. Didn't want it to boil. Just melt slowly.
Stir it little bit, to break down the wax a bit. Then got my Deodorant container and laid some rag underneath it. Got a funnel to help eazy the pouring and not to get any hot melted wax on myself.
After that I put the deodorant stick in the freezer with the container of the left over collinite
After 30 mins in the freezer. I took it out to check to see if it was hard as rock and it was. So this is what I got.
Well this is my little post. Can't wait to try it out to see how it works.
Old May 7, 2008 | 12:28 AM
TheIvoryG's Avatar
Wow...okay...you've got my interest. Have you tried applying? How does it work?
Old May 7, 2008 | 02:15 AM
Scrooge's Avatar
Just did it. Works the same was like if you took the wax out of the jar and apply to a machine pad. Also before you start turning the dial. Let it warm up a little bit or it will crack.
Old May 7, 2008 | 04:16 AM
wrathletik1's Avatar
Very creative!
Old May 8, 2008 | 12:22 AM
Scrooge's Avatar
Originally Posted by wrathletik1
Very creative!
thanks
mbe32
Nov 13, 2015 11:09 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
Paragham
Sep 15, 2015 12:04 AM
