How much pressure to use with PC
I've been doing some research on different styles and techniques to maximize paint correction with PC...but lots of disparity in terms of pressure in order to properly and fully break the product down.
What do you guys do? How much pressure do you apply? I've heard a lot of 12-15 pounds...but that somehow winds up being subjective. One guy said to push until it stops spinning, then let up just enough so it starts spinning again. Others say to apply pressure just until it starts to bog down. I've also seen some people try to count rotations per second. Autopia how to said "just enough pressure to keep the pad in full contact".
I'd love to hear others opinions and techniques. Thanks!
Good luck! Keep us posted on how you make out and what you ended up doing.
George
I apply as much pressure as necessary to just barely begin to bog the buffer down. This differs with the pad stiffness and size, which is why I like to use smaller 4" pads. I can apply more pressure and get better breakdown
Rhinos7777
Sep 6, 2015 05:36 PM
